How does Spin handle the code in an object file?
K so i finally got how to refer my main AI code to a gyroscope object, my question is can i call a pub function to get all axis info at once or do i have to dived it into different pubs for each axis? I'm using the 3-axis gyro.Also do i need to have the Var s in my main code or just having them in object work?
Doing one thing well could mean reading 3 axis from the gyro. Post your code if you need help.
The gyro access function will take one parameter, the address of the array defined above, you can get that address with the @ operator.
When called the gyro access object will write the data for all three axis to their places in the given array.
The gyro access function need not even have a return value but it could be used for returning a success/fail indication or some error code.
