ladder logic
Whatever happened to PICoPLC programming. is the software still available. Does it really work. I have a prop board in my drawer getting dusty and rusty.
What is the latest info.
joe
joe
What I can for you is repost it in this thread so you don't have to look for it.
To answer your other question. Yes it does work and its pretty cool.
I'm develloping a ladder logic compiler for the propeller on the same base (Jonahantan westues ladder logic compiler http://cq.cx/ladder.pl)
If you want I can share it, but it's a devellopement version, and texts are in French, and it can be buggy , but generates SPIN file.
The software is open source, i've made a solution for Microsoft's visual C++ express 2010.
If you are C++ programmer you can modify it for your own usage.
Olivier
I've attached the laddder diagral$mm and the SPIN generated file
Any feedback needed.
Olivier
Here is the SPIN corresponding to the TXT file.
Olivier
