BS2 SIN/SOUT Pins, MAX232 and not enough caffeine...
JordanCClark
I've read enough on this to make my head spin... so what I'm trying to take away from all this is:
Do I need to add a MAX232 to the program port of a BS2, or is that more for if I was going to use an I/O pin for serial comms?
I've already got a board made up with a MAX232 attached to the serial pins, but I'm a-thinkin' that my thinkin' was stinkin' and these boards are now mostly useless-- not a big deal, because my next board rev is adding circuits for other things anyway, but the comms issue came and bit me. Feel free to laugh at my expense-- after all, if I can't laugh at myself, then there's plenty of other people to take up the slack!
Thanks in advance!
Thanks in advance!
The OEM version is discrete chips and is meant to be used in vendor products. It uses TTL voltage and logic, so a MAX232 is used to hook it up to a serial port.
- Norm Abrams
I had jumpered the board around the max232 socket, but still had no joy. It's part of what prompted my original post.
But then I found two things wrong with my board.
1. I had the two caps in, but nothing going to the ATN pin-- efectively two caps in serial between DTR and ground.
2. The footprint in my PCB software apparently made distinction between a male or female conector, so the pinout was incorrect.
That'll teach me to try and design a board after a 30 hour work stint. Too many irons in the fire, and the barn's burning... now where's that smiley for an eye roll?
EDIT: Forgot to add my final results: after soldering in a jumper to the ATN and making a "mega-crossover" cable (1-5, 2-4, etc.) I got a response from the BS2. I can finish out the testing and get a revised board made after that.
Thanks again!
Just to let y'all know, I found two other things wrong. The
