Hi, several years ago I bought the kit boe bot. Eventually I stopped working with the kit and since I lost most of the parts.
Today I found the plate with the micro-controller at the bottom of my drawer and I want to reprogram (history of taking care).
So I connected the turntable via USB and installed the Basic Stamp Editor v 2.3 (cd-rom version). It semblerai I have a problem with the communication of microcontroller including COM 1:
I tested on several PCs with a different cable, I think it's a configuration problem and as I have over the French manual (also can I find the manual in PDF format in French?) I have come post here.
...so, ummm...something about a 9 volt battery ("pile 9 volte")...something about him doing something idiotic ("trover idiot!")...something about using USB instead of a battery, but now all is functioning well ("fonctionne bien").
And you said something about an opportunity to communicate in French, plus "happy roboting"?
Thank you for your help.
Output from Google translate:
Depuis que vous utilisez USB, le probl
Man, that smarted a few synapses!
Ah, you have to stir up the unused ones every once in a while, or they become fat and lazy.
Yeah, he was trying to power the board from USB. Once he powered it correctly, it worked.
...roger that!
