QuickStart doesn't like AC adapters
...or car adapters. I had been planning to deploy several quickstarts for a simple application and power them from mini-USB charger warts. All units work fine on the programming cable, but none work on any of the wall warts. I finally took one out to the car and tried my GPS charging cable, it doesn't work either. The cables are putting out the same 5V as a USB port and the green LED comes on, but not very bright, and the Propeller is undervoltaged at about 2.5V. I see there is a transistor between USB-5V and Vin, but it's not clear why this is misbehaving. Anybody have a solution?
Pin 30 (I think), /USB_PWR.
