Adjusting Sensor Sensitivity on Eddie Platform
I am not sure if this is the appropriate place to put this thread but I would like to know if there is a simple way of adjusting the sensor sensitivity on the Eddie platform. I have fully assembled and played around with my Eddie robot a bit and have noticed that it has quite a lot of difficulty in navigating through my house. It even seems to have trouble going through ordinary sized doorways. Is there an easy way of turning down the sensitivity a bit so that the robot can get closer to objects?
Thanks for any help,
Paul
P.S. Has anyone played around with avoiding stairs with the Eddie? I think that mine might fall right down the steps if I don't intervene! Not cool.
Paul
Paul
If you're running Eddie using the Robot Dashboard, you can adjust the PID controller using the Obstacle Avoidance window. I ran into some of the same issues with Eddie not being able to easily navigate through doorjams. This is only available through Eddie.cmd and not EddieDirect.cmd.
Hope this helps!
Cheers,
Jess
