A/D Converter using IC "TC500ACPE"
Hi there,
Anyone use TC500ACPE for Analog to Digital Converter before? Thank you....
From,
jonykk
From,
jonykk
http://www.microchip.com/wwwproducts/Devices.aspx?dDocName=en010518
Why do you need it?
If this converter is unlikely to use. Can you please recommend me a better one? I need a 16bit ADC...Thank you...
Thanks for your reply... After all the research i had done... I decided to get LCT1298... http://www.parallax.com/dl/docs/prod/appkit/ltc1298.pdf and i read through the http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol2/col/nv57.pdf
I found that it is better to get a 12bit ADC and use some idea of Getting the Most Out of Your 12-Bit ADC.
Or maybe if anyone have an better idea please let me know...Thank you...
