Boe Bot Battery Charge Level
Hi Everyone ![:) :)](https://forums.parallax.com/resources/emoji/smile.png)
Is there a way to determine the charge level of the batteries of my boe bot? Im using the Li-ion battery pack and what I want to be able to do is check the charge level of the batteries and if they are at a pre-determined level I can have it move to a certain position.
Cheers,
Cheers,
I looked for an online version of the schematic but couldn't find one. But with some digging you might be able to. As an aside Gordon's book is often the first place I go with questions like this because it usually has the answer.
Martin's suggestion is good - Gordon's book is a "must have" IMHO...here's another tactic:
You could put a simple a/d converter on the BoeBot (like and ADC0831) - the code's readily available, and then you could monitor the level as it's dropping during use. In my tests here, (if I remember correctly), I think the BoeBot will run for 6 hours? on a fully charged Lion pack.
-MattG
