PING sensor moisture protection
ok what would you use to protect the PING sensor from water yet still have it function.
I was thinking plastic film over the opening.
any of you have any experience with this?
I made a rather big robot years ago and while it has weathered well with its IR sensors, I wanted to add sonar but noticed the moisture warning.
think Roomba but 2 feet wide metal and you can sit on it
http://www.futurlec.com/Ultrasonic_Sensors.shtml
http://www.robotshop.com/senix-tspc-30s1-waterproof-ultrasonic-sensor-1.html
None are cheap but all should work for you.
still though I am curious if anyone has seen a protective cover for the PING sensor.
if not some one make it, and sell it, id buy it.
Drill two 5/8" holes in the lid, then push it carefully onto the ping,(it will be tight!),
Make a hole in the box for the cable, and your good to go...
It's not in the picture, but I also use the fuzzy foam covers from a pair of small "over the ear" speakers,
Just slip them over the top of the transducer's,..I think any speaker foam should work.
-Tommy
