[PASM] Can't get Coginit instruction to work
Wossname
EDIT: This thread is solved and I've posted a demo program that is related to the discussion in this thread...
http://wardyprojects.blogspot.co.uk/2012/04/propeller-programming-8-cogs-running.html
I'm making Cog 0 run a "bootstrapper" written in PASM. So far so good, that works.
What I am having trouble with is starting another cog (cog 7 in fact, not that it's important) from within the bootstrapper code using the coginit instruction in PASM. The PASM code I want to put in cog 7 never runs so I must be constructing the bit fields incorrectly, so cog 7 never starts up.
I've carefully checked the field alignments and I believe them to be correct as per the Prop Manual. Therefore the numbers I'm passing in must be wrong within those bit fields.
I'd be most grateful if someone could have a quick look at my code please. Just put LEDs on P0 and P1 and run the code. In my broken code only P0's LED flashes, in working code they should both be flashing (and different speeds)...
The manual could REALLY do with a worked example of how to realistically use coginit in PASM (not just the spin version).
CON
'_clkmode = RCFAST
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
PUB Main
coginit(0, @BOOTSTRAPPER, 0)
DAT
org 0
'I want these 8 lines of cog config info to be stored in the HUB but *NOT* in the cog ram when the cogs start up
'I want the coginit call to pass these hub addresses to the cogs when they start up...
'IO PIN, loop delay
cog7_config long 7, 80_000_000
cog6_config long 6, 79_000_000
cog5_config long 5, 78_000_000
cog4_config long 4, 77_000_000
cog3_config long 3, 76_000_000
cog2_config long 2, 75_000_000
cog1_config long 1, 74_000_000
cog0_config long 0, 73_000_000
fit
org 0
BOOTSTRAPPER
or dira, #1
'COGINIT instruction setup see Propeller Manual (PASM Instruction Set) for bit-field
mov boot_settings, @cog7_config 'bad syntax???
andn boot_settings, #$03
shl boot_settings, #14
or boot_settings, #COG7_CODE 'bad syntax???
shl boot_settings, #2
andn boot_settings, #$0f
or boot_settings, #7 'RUN IN COG SEVEN!
coginit boot_settings
'---------------------------------- FINISHED SETUP FOR COG7
mov boot_time, cnt
add boot_time, #16
:loop waitcnt boot_time, boot_delay
xor outa, #1
jmp #:loop 'WAIT IN THIS LOOP FOREVER, blinking LED on P0
boot_delay long 10_000_000
boot_settings res 1
boot_time res 1
fit
org 0
COG7_CODE
'DEBUGGING
or dira, #2
mov c7_time, cnt
add c7_time, #16
:debugloop waitcnt c7_time, C7_DEBUG_DELAY
xor outa, #2
jmp #:debugloop
mov c7_parptr, par
rdlong c7_temp, c7_parptr 'fetch the IO pin number
mov c7_ledPin, #1 'this 1 will be shifted into the right position
shl c7_ledPin, c7_temp 'c7_ledPin now correctly nominates a single IO pin in OUTA
or dira, c7_ledPin 'enable output on that nominated IO pin
add c7_parptr, #4 'move the parameter pointer to the next LONG value in Hub RAM
rdlong c7_delay, c7_parptr 'fetch the timer delay interval from that address
mov c7_time, cnt
add c7_time, #16
:loop waitcnt c7_time, c7_delay
xor outa, c7_ledPin
jmp #:loop
C7_DEBUG_DELAY long 4_000_000
c7_parptr res 1
c7_ledPin res 1
c7_delay res 1
c7_time res 1
c7_temp res 1
fit
This is just quick and dirty. I extended the table to include the code address (cog 7 only). I also pass the real (final) address of the table to the bootstrap cog. The bootstrap cog first calculates the offset by adding par to reference. Then it picks the right table entry and extracts the code address, adjusts the latter and constructs the coginit parameter in the normal way. As an example I flash the LED bar of the demo board with 0.5Hz.
CON _clkmode = XTAL1|PLL16X _xinfreq = 5_000_000 PUB Main coginit(cogid, @BOOTSTRAPPER, @cog0_config) DAT 'I want these 8 lines of cog config info to be stored in the HUB but *NOT* in the cog ram when the cogs start up 'I want the coginit call to pass these hub addresses to the cogs when they start up... 'IO PIN, loop delay cog0_config long 0, 73_000_000, 0 cog1_config long 1, 74_000_000, 0 cog2_config long 2, 75_000_000, 0 cog3_config long 3, 76_000_000, 0 cog4_config long 4, 77_000_000, 0 cog5_config long 5, 78_000_000, 0 cog6_config long 6, 79_000_000, 0 cog7_config long 7, 80_000_000, @COG7_CODE fit DAT org 0 BOOTSTRAPPER add reference, par ' adjust for runtime delta mov temp, par ' @cog0_config add temp, #12*7{ID} ' @cog7_config mov boot_settings, temp shl boot_settings, #16 ' %pppppppp_pppppp00_00000000_00000000 or boot_settings, #7{ID} ' %pppppppp_pppppp00_00000000_00000111 add temp, #8 ' @cog7_config[2] rdlong temp, temp ' @COG7_CODE in DAT context add temp, reference ' adjust shl temp, #2 ' %00000000_000000aa_aaaaaaaa_aaaa0000 or boot_settings, temp ' done coginit boot_settings '---------------------------------- FINISHED SETUP FOR COG7 waitpeq $, #0 reference long -@cog0_config boot_settings res 1 temp res 1 fit DAT org 0 COG7_CODE mov dira, mask rdlong delay, #0 mov cnt, cnt add cnt, #9 waitcnt cnt, delay xor outa, mask jmp #$-2 mask long $00FF0000 delay res 1 fit DATI don't entirely understand the finer points of hub ram address allocations but I have worked your changes into my test app and now I have all 8 cogs running PASM and all of them taking their runtime parameters from the cog_config data table.
I'm going to tidy my code up a bit, cram it full of explanatory comments and then post it on my blog as a template for anyone else to use.
Thank you very much for your help!
(I'll post a link to my blog in a bit...)
Thanks again Kuroneko, much appreciated
