Need PING hole mounting dimensions — Parallax Forums
ercoerco Posts: 20,261
edited 2012-04-11 11:24 in General Discussion
Can someone help me out? I'm at work, ready to drill two PING mounting holes in aluminum, but I left my PING at home. Need the x & y distances for the two holes and diameter. Thanks!
BTW, it's to mount a PING on the front of this Flame-Boe-Yant robot:
    edited 2012-04-11 10:38
    I've got my Ping here.
    Measuring. Please stand by.
    edited 2012-04-11 10:44
    This appears metric friendly.
    The mounting holes (centers) are 40.0mm away in the X direction and 16.0mm in Y direction.
    The holes are 3.25mm in diameter (measuring as if there were four holes).
    (Go with Ron's diagram.)
    4-40 machine screws fit through the holes. There's not a lot of clearance between the mounting holes and the transducers.
    Edit: Sorry erco, I don't know where that 20mm (as earlier posted) came from (other than my brain (I interrupted doing taxes to measure)).
    I doubt it comes as a surprise (nor should it) the actually PCB dimensions don't exactly match the diagram. Most dimension are off by 0.1mm. The long dimension is off by a couple of tenths. Not that this is a big deal.
    edited 2012-04-11 10:49
    Here is a diagram
    517 x 280 - 32K
  • jdoleckijdolecki Posts: 726
    edited 2012-04-11 10:50
    here ya go
    561 x 341 - 41K
    edited 2012-04-11 10:53
    jdolecki wrote: »
    here ya go
    Beat ya! :smile:
    YEW BOYZ ROK!
    Thanks!
