I cannot read the schematics for experiment 29: Temperature Measurement in the StampWorks manual. Can anyone post a wiring diagram or an images of the assembled experiment. Thanks.
What part of the schematic(s) do you have difficulty with?
The small numbers around the box of the DS1620 are the pin numbers. As is true of all ICs, they are numbered starting at 1 counter-clockwise from the dot or indentation. If there's only an indentation along one side of the package, that indicates the top with pin 1 at the upper left hand corner.
The various experiments in the StampWorks manual are tested and do work as described. If you cannot get it to work, then we need to find out what's different about your setup and your program. It's very helpful for you to post your actual code, not what you think you've entered ... often that's where the problem lies. Similarly, it would be helpful if you could post a schematic drawn from your actual layout or a picture of your board if that's clear enough. If your program does display some data, it would be helpful to see what that is.
