Non dallas 1-wire devices
Hi, new to the forum but somewhat familiar with programing mostly industrial controls.
I purchased 8 , 1-wire 7-segment displays from sparks fun (part# com-09763) thinking I could string them all together on the Bs2p 1-wire buss pin. to display readings from various sensors, some of the sensors are Dallas 1-wire devices (DS2760 thermocouple modules) + additional analog sensors.
The problem I am having is that the sparks fun LED display control chip ( ATMega328) is not programed with a serial number to identify which display to send any one of the sensors readings to .
I e-mailed and called sparks fun, seems there all arduion fans and said it was possible with newsoftserial on the Arduino platform but had no clue if stringing the displays togeather on the Bs2p could be done. below is there response,
response 1................The 7-segment displays do not have serial numbers. Let me know if you have any other questions.
response2..........I wasn't able to find any info how to have multiple serial devices using the Basic Stamp. I asked around in our Engineering department and no one really used Basic Stamp here either. It seems like you will need to write a software serial implementation. (Kind of like NewSoftSerial for Arduino) I recommend going on the Parallax forums to see if the community members have hints. The Parallex support team would have the best idea who to do this. Sorry that we don't have a better answer for you!
without a serial number to point to i don't see how I can run more than 1 these off the 1-wire buss, the only solution I have been able to see is running them off of pins 1-8 with multiple serout commands but haven't tried it yet and that eats up more pins than i would like.
anyone out there have any idea what my best solution would be or how to tag these displays individually,
thanks,
[h=3][/h]
thanks,
[h=3][/h]
It would be possible to use external devices, like a decoder (a 74HC138 for up to 8 devices each). This would take 4 I/O pins plus one for each group of 8 displays. If you need more than 24 displays, you could always use another 74HC138 to select one of the other 74HC138s and need only 7 I/O pins for up to 64 displays.
thanks for the prompt reply, This forum is very helpful and informative.
thanks,
