Source for board terminals for ring terminal connectors?
I have been searching but not coming up with the right search term I guess.
I am looking for a solderable part for attaching these ring terminal connectors to the board.
I have used screw terminals in the past, but I am tired of wires slipping out or not easily going into the holes. I would like
to switch to using these.
Solder first, then crimp with pliers for some stain relief.
Ragtop,
Keystone has what you're looking for: http://www.keyelco.com/pdfs/M55-prod19.pdf
I agree. The proper way to terminate is with the proper termination tool, but most people don't want to spend the $60-$80 for the correct tool. The $8.00 tools at Radio Shack don't seem to cut it. For a field repaid, I solder only the front of the terminal, just behind the ring, and crimp the back to alleviate the possibly of breakage.
