Getting started: Thermistor and LM34
It has been years since I played with my Basic Stamp 2, but I have a project it would be perfect for and I need some help getting started.
The project will involve monitoring the temperature of both water (30deg F - 40deg F) and air (40deg F to 110deg F).
I have ordered some LM34s but as I'm waiting for delivery, I found some Radio Shack 10k-Ohm Thermistors 271-110A.
My research of the site has lead me to http://www.parallax.com/Portals/0/Downloads/appnt/stamps/bs1Appnotes.pdf page 33 (using a thermistor) and I wanted to give it a go.
I loaded the code into the editor, but I get a syntax error
"Expected ':' or end-of-line"
at this point
"Symbol co0 = 162"
I'm guessing this has to do with this code being for a BS1 and not a BS2, but I'm having trouble figuring out what is causing it.
Thanks in advance for the help.
JM
at this point
"Symbol co0 = 162"
JM
I removed the keyword Symbol but I get the same error.
and found the [ code ] [ / code ] tags
http://forums.parallax.com/misc.php?do=bbcode#code
I got the code to output some data to the debug window by adding 'DEBUG DEC W0' the DEC was missing.
Now all I get are 000000 in the window.
Any thoughts on how to figure out what is going on?
I'm a bit confused on what wiring to use, and then there is the math to convert the output to temp....
I could use a good example that someone knows works on the BS2.
