Spin help
Cenlasoft
Hello,
I am trying to send a squarewave on two pins that are 180 degrees apart. I got that done I think. I am using an h-bridge to excite an ultrasonic transducer. from 5 V I will come out with a 10 vpp. It works. My spin code has something wrong. On the scope I see a squarewave (40KHZ). How do I time it to get .5 ms of the 40khz pulse then turnoff the h-bridge and listen for an echo.
Thanks, Cenlasoft
Thanks, Cenlasoft
{{ Template.spin Curtis Desselles }} Con _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 Pin1 = 0 Pin2 = 1 Var Obj Pub Main repeat TX_Out 'TX a pulse x 5 dira[Pin1..Pin2]~~ 'Make pins output outa[Pin1..Pin2] := %00 'Turn off h-bridge Pub TX_Out | i repeat i from 0 to 4 ctra := %00101 <<26 + Pin2<<9 +Pin1 frqa := 1<<31 / (clkfreq / 80_000) dira |= |<Pin1 + |<Pin2 Return
2) If you still want pins 1 and 2 to be outputs with the h-bridge off, you could zero CTRA and do: OUTA[Pin1..Pin2]~ or OUTA[Pin1..Pin2] := $00
3) To get a particular pulse length, just wait that time, then set CTRA and the output pins to zero. Use: WAITCNT(CLKFREQ/2000 + CNT)
4) Remember that other statements will take a few microseconds. That may affect the 0.5ms pulse length. You may have to shorten the delay to compensate.
The code brackets use [] not <>
Andy
Cenlasoft.
dira[Pin0..Pin1] := %11 'ON
dira[Pin0..Pin1] := %00 'OFF
Andy
Mickster
