Help with enabling Parallax RFID Reader
Hello,
I am using an Arduino Uno with the parallax RFID reader 28140. After having connected the 4 pins, i can't get the led to go red. i have checked connections and get +5v at Vcc pin, and made a small bit of code for the enable pin to alternate between high and low, and measure a voltage of +5/0 on the Enable pin, the ground is connected as well.
Why doesn't the led turn red when the enable pin is low?
