is there a voice command module compatible with the propeller? i looked into "say it module", but its discontinued and only worked with basic stamp. -mike
And you can use the SayIt or EasyVR with the Propeller. There's a link to a simple bridge program in my index (probably post #2) to use the SayIt GUI with the Propeller.
I have two SayIt modules. I removed the EasyVR module from one of them because the SayIt was larger than just the module by itself.
Edit: Just do a search for EasyVR. I found this one.
SparkFun sells this.
