No propeller chip found, home brew board, Serial Terminal looks like it working...
rwgast_logicdesign
Ok so I finally got all my stuff in the mail, I built a simple power regulator circut on some pref board then followed the simple propeller schematics on in the prop manual, have not added a crystal yet though.
When I hit f7 spin tool says no propeller chip found on com 3, but when i use the serial terminal and type RX, and TX both light up, when i hit my reset switch RX, flashes, when I hold the reset button as I type only TX will flash and RX stays dead until I let go of the reset. It looks to me like there is serial communication going on.. no conflicts or driver issues with win7 x64, so what could be the cause of prop tool telling me no prop chip on com 3. I checked my wiring Im pretty sure its right, anyone know if this is software or hardware and what it could be? Hmmm also just noticed if i flip the power to the board turning echo on off stops echoing, but if the board is on the echoing wont turn off, and when checked on I it shows doubles.
did you change the com-port to "auto" in the propeller-tool?
From what you have described so far it could be hardware or software.
As you have a DIY-board please post a schematic.
What kind of USB-to-serial-adapater are you using?
What do you mean by saying Do have loaded a serial test-prg into the EEPROM that does send characters? If yes how did you manage to load this Prg into the EEPROM?
If not this is no echoing just the Rx/TX flashing when powering up or connect to an USB-port
best regards
Stefan
