weird power on spinneret
I was wondering if anyone had the same issue as me. I plugged mine in then it turned on for a split second and got really hot then turned off. I just ordered a new web server got it on friday and decided to power it up. I have an adjustable power supply that goes from less than a volt to 24 volts with a digital read out on the front. I read the documentation before hand and it said anywhere from 3-3.6 correct? Also you can use a different setup for from 4 to 9 v right?. Set my adjustable psu to 3v at 200 Mah's because idle is uses 175 Mahs.
I guess what I am getting at is, there anyone that has had a power problem with theirs where it just stops working and gets really hot?
provide power from a 3.0 to 3.6 VDC source, use J1 and connect pin 2 to ground, and either pin 1 to
power. For a 4.0 to 9.0 VDC supply, either use J1 and connect pin 2 to ground and pin 12 to power, or
use J6 and connect pin 3, labeled 'B', to ground and pin 2, labeled 'R', to power. When providing power
from a 4.0 to 9.0 VDC supply on either J1 or J6, the same voltage will be output on the corresponding pin
of the other connector. Pin 12 of J1 will also output a regulated 3.3 VDC supply. [Not true.
When 4-6V is applied to J6 or pin 12 of J1, pin 1 of J1 will exhibit a regulated 3.3V.] Make sure that any
connected devices are tolerant of these voltages. Do not simultaneously supply power to multiple pins."
Since you've got a variable DC supply, I would apply 5V to J6 as I outlined above.
