+ and - 5v power supply
Hi guys!
I need help on the following issues.
I'm trying to build a dual 5v power supply for one of my application in my hardware. and below are the list of the item i have in my hand:
LM7805
LM7905
9v DC battery as input power for my regulator
Im able to get the 5v regulated power out from 7805 with the negative end of the power supply as ground. but i cant seems to get 7905 to work properly. and i know that both output should have a common ground. can anyone teach me how should i build this?
Thanks a million for reading this guys! and the help too!
Kelun
LM7805
LM7905
Kelun
N.B.The pin out of the 7805 (I-G-O) isn't the same as a 7905 (G-I-O).
@PJ : hi PJ thank you for the reply! i am not using a center tap transformer as my design only require me to use 9v battery. and yeah i notice the pin are different too. but just cant get it to work. =(
if i were to use different battery for both regulator, do i just connect 7805 GND pin with 7905 GND pin together to form the common ground?
Below are the connection set up from what i know, please let me know if i am wrong.
>> for 7805, the INPUT pin is connected to the positive end of the battery and the GROUND pin is connected to the negative end of the battery.
>> for 7905, the INPUT pin is connected to the negative end of the battery and the GROUND pin is connected to the positive end of the battery.
this is the part which make me cant get the "common" ground.
or if it is possible, will you mind showing me the overall diagram as to help me to visualize it? really appreciate it!
I do suggest that you have a DPST (Double Pole Single Throw) power switch connected between the batteries and the regulators. That would allow you to turn things on and off without removing the batteries. It's optional. One side of the switch would go between the positive end of one battery and the 7805 input and the other side of the switch would go between the negative end of the other battery and the 7905 input.
Kelun
Well... OK, but this won't last long.
"...will you mind showing me the overall diagram as to help me to visualize it?"
