Eddie Assembly Questions
Hi
Almost done assembling my first Eddie Robot .had a few questions around wiring that I thought Id post dont want to get wiring wrong and blow something up :-)
Regards
Apoorav
- Only the right position controller is connected to the controller board (pin 11) Correct? The instructions around wiring of position controllers is kind of not very clear...
- Anyone has a picture of a fully wired Controller Board? ...just wanted to check I got it right!!
Regards
Apoorav
Left Motor: Both jumpers installed. From the "To Controller" section, connect a servo extension cable to the top set of headers, and run that to the right motor's bottom set of headers in the "To Controller" section.
Right Motor: "A" jumper installed, "B" jumper removed. From the "To Controller" section, connect a servo extension cable to the top set of headers, and run that to I/O Pin 11.
