Test Forum -> code formatting to HTML formatting
SRLM
1. To format your code in HTML, first use the SPIN -> BB FORUM formatter tool: http://www.phipi.com/format/
2. Post your code into a post somewhere and put the post up on the forums. Then view the page source and locate your code.
3. Copy your code between the < pre > < /pre > tags.
4. With the same original code, use the blogspot CODE -> HTML formatter tool: http://codeformatter.blogspot.com/
5. From the HTML from step 4, replace everything between the <pre> tags with the copied code from step 3
The advantage of this is that your HTML code post now has basic (ie bold keywords) code formatting.
Example forum post that has code from phipi code format:
___________________________________________________________________
'' From Parallax Inc. Propeller Education Kit - Objects Lab v1.1 {{ ──────────────────────────────────────────────────────────────────────────────────────── File: FullDuplexSerialPlus.spin Version: 1.1 Copyright (c) 2008 Parallax, Inc. See end of file for terms of use. This is the FullDuplexSerial object v1.1 [b]from[/b] the Propeller Tool's Library folder with modified documentation [b]and[/b] methods for converting text strings into numeric values in several bases. ──────────────────────────────────────────────────────────────────────────────────────── Note: used by Anzhelka project }} [b]CON[/b] '' ''Parallax Serial Terminal Control Character Constants ''──────────────────────────────────────────────────── HOME = 1 ''HOME = 1 CRSRXY = 2 ''CRSRXY = 2 CRSRLF = 3 ''CRSRLF = 3 CRSRRT = 4 ''CRSRRT = 4 CRSRUP = 5 ''CRSRUP = 5 CRSRDN = 6 ''CRSRDN = 6 BELL = 7 ''BELL = 7 BKSP = 8 ''BKSP = 8 TAB = 9 ''TAB = 9 LF = 10 ''LF = 10 CLREOL = 11 ''CLREOL = 11 CLRDN = 12 ''CLRDN = 12 CR = 13 ''CR = 13 CRSRX = 14 ''CRSRX = 14 CRSRY = 15 ''CRSRY = 15 CLS = 16 ''CLS = 16 [b]VAR[/b] [b]long[/b] cog 'cog flag/id [b]long[/b] rx_head '9 contiguous longs [b]long[/b] rx_tail [b]long[/b] tx_head [b]long[/b] tx_tail [b]long[/b] rx_pin [b]long[/b] tx_pin [b]long[/b] rxtx_mode [b]long[/b] bit_ticks [b]long[/b] buffer_ptr [b]byte[/b] rx_buffer[*16] 'transmit and receive buffers [b]byte[/b] tx_buffer[*16] [b]PUB[/b] start(rxpin, txpin, mode, baudrate) : okay {{ Starts serial driver in a new cog rxpin - input receives signals [b]from[/b] peripheral's TX pin txpin - output sends signals to peripheral's RX pin mode - bits in this variable configure signaling bit 0 inverts rx bit 1 inverts tx bit 2 open drain/source tx bit 3 ignor tx echo on rx baudrate - bits per second okay - returns [b]false[/b] [b]if[/b] no cog is available. }} stop [b]longfill[/b](@rx_head, 0, 4) [b]longmove[/b](@rx_pin, @rxpin, 3) bit_ticks := clkfreq / baudrate buffer_ptr := @rx_buffer okay := cog := [b]cognew[/b](@entry, @rx_head) + 1 [b]PUB[/b] stop '' Stops serial driver - frees a cog [b]if[/b] cog [b]cogstop[/b](cog~ - 1) [b]longfill[/b](@rx_head, 0, 9) [b]PUB[/b] tx(txbyte) '' Sends byte (may wait for room in buffer) [b]repeat[/b] [b]until[/b] (tx_tail <> (tx_head + 1) & $F) tx_buffer[*tx_head] := txbyte tx_head := (tx_head + 1) & $F [b]if[/b] rxtx_mode & %1000 rx [b]PUB[/b] rx : rxbyte '' Receives byte (may wait for byte) '' rxbyte returns $00..$FF [b]repeat[/b] [b]while[/b] (rxbyte := rxcheck) < 0 [b]PUB[/b] rxflush '' Flush receive buffer [b]repeat[/b] [b]while[/b] rxcheck => 0 [b]PUB[/b] rxcheck : rxbyte '' Check if byte received (never waits) '' rxbyte returns -1 if no byte received, $00..$FF if byte rxbyte-- [b]if[/b] rx_tail <> rx_head rxbyte := rx_buffer[*rx_tail] rx_tail := (rx_tail + 1) & $F [b]PUB[/b] rxtime(ms) : rxbyte | t '' Wait ms milliseconds for a byte to be received '' returns -1 if no byte received, $00..$FF if byte t := [b]cnt[/b] [b]repeat[/b] [b]until[/b] (rxbyte := rxcheck) => 0 [b]or[/b] ([b]cnt[/b] - t) / (clkfreq / 1000) > ms [b]PUB[/b] [b]str[/b](stringptr) '' Send zero terminated string that starts at the stringptr memory address [b]repeat[/b] [b]strsize[/b](stringptr) tx([b]byte[/b][*stringptr++]) [b]PUB[/b] getstr(stringptr) | index '' Gets zero terminated string and stores it, starting at the stringptr memory address index~ [b]repeat[/b] [b]until[/b] (([b]byte[/b][*stringptr][*index++] := rx) == 13) [b]byte[/b][*stringptr][*--index]~ [b]PUB[/b] dec(value) | i '' Prints a decimal number [b]if[/b] value < 0 -value tx("-") i := 1_000_000_000 [b]repeat[/b] 10 [b]if[/b] value => i tx(value / i + "0") value //= i [b]result[/b]~~ [b]elseif[/b] [b]result[/b] [b]or[/b] i == 1 tx("0") i /= 10 [b]PUB[/b] GetDec : value | tempstr[*11] '' Gets decimal character representation of a number from the terminal '' Returns the corresponding value GetStr(@tempstr) value := StrToDec(@tempstr) [b]PUB[/b] StrToDec(stringptr) : value | char, index, multiply '' Converts a zero terminated string representation of a decimal number to a value value := index := 0 [b]repeat[/b] [b]until[/b] ((char := [b]byte[/b][*stringptr][*index++]) == 0) [b]if[/b] char => "0" [b]and[/b] char =< "9" value := value * 10 + (char - "0") [b]if[/b] [b]byte[/b][*stringptr] == "-" value := - value [b]PUB[/b] bin(value, digits) '' Sends the character representation of a binary number to the terminal. value <<= 32 - digits [b]repeat[/b] digits tx((value <-= 1) & 1 + "0") [b]PUB[/b] GetBin : value | tempstr[*11] '' Gets binary character representation of a number from the terminal '' Returns the corresponding value GetStr(@tempstr) value := StrToBin(@tempstr) [b]PUB[/b] StrToBin(stringptr) : value | char, index '' Converts a zero terminated string representaton of a binary number to a value value := index := 0 [b]repeat[/b] [b]until[/b] ((char := [b]byte[/b][*stringptr][*index++]) == 0) [b]if[/b] char => "0" [b]and[/b] char =< "1" value := value * 2 + (char - "0") [b]if[/b] [b]byte[/b][*stringptr] == "-" value := - value [b]PUB[/b] hex(value, digits) '' Print a hexadecimal number value <<= (8 - digits) << 2 [b]repeat[/b] digits tx([b]lookupz[/b]((value <-= 4) & $F : "0".."9", "A".."F")) [b]PUB[/b] GetHex : value | tempstr[*11] '' Gets hexadecimal character representation of a number from the terminal '' Returns the corresponding value GetStr(@tempstr) value := StrToHex(@tempstr) [b]PUB[/b] StrToHex(stringptr) : value | char, index '' Converts a zero terminated string representaton of a hexadecimal number to a value value := index := 0 [b]repeat[/b] [b]until[/b] ((char := [b]byte[/b][*stringptr][*index++]) == 0) [b]if[/b] (char => "0" [b]and[/b] char =< "9") value := value * 16 + (char - "0") [b]elseif[/b] (char => "A" [b]and[/b] char =< "F") value := value * 16 + (10 + char - "A") [b]elseif[/b](char => "a" [b]and[/b] char =< "f") value := value * 16 + (10 + char - "a") [b]if[/b] [b]byte[/b][*stringptr] == "-" value := - value [b]DAT[/b] '*********************************** '* Assembly language serial driver * '*********************************** [b]org[/b] ' ' ' Entry ' entry [b]mov[/b] t1,[b]par[/b] 'get structure address [b]add[/b] t1,#4 << 2 'skip past heads and tails [b]rdlong[/b] t2,t1 'get rx_pin [b]mov[/b] rxmask,#1 [b]shl[/b] rxmask,t2 [b]add[/b] t1,#4 'get tx_pin [b]rdlong[/b] t2,t1 [b]mov[/b] txmask,#1 [b]shl[/b] txmask,t2 [b]add[/b] t1,#4 'get rxtx_mode [b]rdlong[/b] rxtxmode,t1 [b]add[/b] t1,#4 'get bit_ticks [b]rdlong[/b] bitticks,t1 [b]add[/b] t1,#4 'get buffer_ptr [b]rdlong[/b] rxbuff,t1 [b]mov[/b] txbuff,rxbuff [b]add[/b] txbuff,#16 [b]test[/b] rxtxmode,#%100 [b]wz[/b] 'init tx pin according to mode [b]test[/b] rxtxmode,#%010 [b]wc[/b] [b]if_z_ne_c[/b] [b]or[/b] [b]outa[/b],txmask [b]if_z[/b] [b]or[/b] [b]dira[/b],txmask [b]mov[/b] txcode,#transmit 'initialize ping-pong multitasking ' ' ' Receive ' receive [b]jmpret[/b] rxcode,txcode 'run chunk of tx code, then return [b]test[/b] rxtxmode,#%001 [b]wz[/b] 'wait for start bit on rx pin [b]test[/b] rxmask,[b]ina[/b] [b]wc[/b] [b]if_z_eq_c[/b] [b]jmp[/b] #receive [b]mov[/b] rxbits,#9 'ready to receive byte [b]mov[/b] rxcnt,bitticks [b]shr[/b] rxcnt,#1 [b]add[/b] rxcnt,[b]cnt[/b] :bit [b]add[/b] rxcnt,bitticks 'ready next bit period :wait [b]jmpret[/b] rxcode,txcode 'run chunk of tx code, then return [b]mov[/b] t1,rxcnt 'check if bit receive period done [b]sub[/b] t1,[b]cnt[/b] [b]cmps[/b] t1,#0 [b]wc[/b] [b]if_nc[/b] [b]jmp[/b] #:wait [b]test[/b] rxmask,[b]ina[/b] [b]wc[/b] 'receive bit on rx pin [b]rcr[/b] rxdata,#1 [b]djnz[/b] rxbits,#:bit [b]shr[/b] rxdata,#32-9 'justify and trim received byte [b]and[/b] rxdata,#$FF [b]test[/b] rxtxmode,#%001 [b]wz[/b] 'if rx inverted, invert byte [b]if_nz[/b] [b]xor[/b] rxdata,#$FF [b]rdlong[/b] t2,[b]par[/b] 'save received byte and inc head [b]add[/b] t2,rxbuff [b]wrbyte[/b] rxdata,t2 [b]sub[/b] t2,rxbuff [b]add[/b] t2,#1 [b]and[/b] t2,#$0F [b]wrlong[/b] t2,[b]par[/b] [b]jmp[/b] #receive 'byte done, receive next byte ' ' ' Transmit ' transmit [b]jmpret[/b] txcode,rxcode 'run chunk of rx code, then return [b]mov[/b] t1,[b]par[/b] 'check for head <> tail [b]add[/b] t1,#2 << 2 [b]rdlong[/b] t2,t1 [b]add[/b] t1,#1 << 2 [b]rdlong[/b] t3,t1 [b]cmp[/b] t2,t3 [b]wz[/b] [b]if_z[/b] [b]jmp[/b] #transmit [b]add[/b] t3,txbuff 'get byte and inc tail [b]rdbyte[/b] txdata,t3 [b]sub[/b] t3,txbuff [b]add[/b] t3,#1 [b]and[/b] t3,#$0F [b]wrlong[/b] t3,t1 [b]or[/b] txdata,#$100 'ready byte to transmit [b]shl[/b] txdata,#2 [b]or[/b] txdata,#1 [b]mov[/b] txbits,#11 [b]mov[/b] txcnt,[b]cnt[/b] :bit [b]test[/b] rxtxmode,#%100 [b]wz[/b] 'output bit on tx pin [b]test[/b] rxtxmode,#%010 [b]wc[/b] 'according to mode [b]if_z_and_c[/b] [b]xor[/b] txdata,#1 [b]shr[/b] txdata,#1 [b]wc[/b] [b]if_z[/b] [b]muxc[/b] [b]outa[/b],txmask [b]if_nz[/b] [b]muxnc[/b] [b]dira[/b],txmask [b]add[/b] txcnt,bitticks 'ready next cnt :wait [b]jmpret[/b] txcode,rxcode 'run chunk of rx code, then return [b]mov[/b] t1,txcnt 'check if bit transmit period done [b]sub[/b] t1,[b]cnt[/b] [b]cmps[/b] t1,#0 [b]wc[/b] [b]if_nc[/b] [b]jmp[/b] #:wait [b]djnz[/b] txbits,#:bit 'another bit to transmit? [b]jmp[/b] #transmit 'byte done, transmit next byte ' ' ' Uninitialized data ' t1 [b]res[/b] 1 t2 [b]res[/b] 1 t3 [b]res[/b] 1 rxtxmode [b]res[/b] 1 bitticks [b]res[/b] 1 rxmask [b]res[/b] 1 rxbuff [b]res[/b] 1 rxdata [b]res[/b] 1 rxbits [b]res[/b] 1 rxcnt [b]res[/b] 1 rxcode [b]res[/b] 1 txmask [b]res[/b] 1 txbuff [b]res[/b] 1 txdata [b]res[/b] 1 txbits [b]res[/b] 1 txcnt [b]res[/b] 1 txcode [b]res[/b] 1 {{ ┌──────────────────────────────────────────────────────────────────────────────────────┐ │ TERMS OF USE: MIT License │ ├──────────────────────────────────────────────────────────────────────────────────────┤ │Permission is hereby granted, free of charge, to any person obtaining a copy of this │ │software [b]and[/b] associated documentation files (the "Software"), to deal in the Software │ │without restriction, including without limitation the rights to use, copy, modify, │ │merge, publish, distribute, sublicense, [b]and[/b]/[b]or[/b] sell copies of the Software, [b]and[/b] to │ │permit persons to whom the Software is furnished to do so, subject to the following │ │conditions: │ │ │ │ │ │The above copyright notice [b]and[/b] this permission notice shall be included in all copies │ │[b]or[/b] substantial portions of the Software. │ │ │ │ │THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS [b]OR[/b] IMPLIED, │ │INCLUDING BUT [b]NOT[/b] LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A │ │PARTICULAR PURPOSE [b]AND[/b] NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS [b]OR[/b] COPYRIGHT │ │HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES [b]OR[/b] [b]OTHER[/b] LIABILITY, WHETHER IN AN ACTION │ │OF CONTRACT, TORT [b]OR[/b] OTHERWISE, ARISING [b]FROM[/b], OUT OF [b]OR[/b] IN CONNECTION WITH THE │ │SOFTWARE [b]OR[/b] THE USE [b]OR[/b] [b]OTHER[/b] DEALINGS IN THE SOFTWARE. │ └──────────────────────────────────────────────────────────────────────────────────────┘ }}
I don't think that works right anymore. Look at your subscripts. I need to revisit the code formater to be compatible with the new forum.
Also, I notice that the phipi.com/format will format keywords inside of comments, eg "from" and "and" in the above FullDuplexSerialPlus.spin
Edit: Ah, you mean the subscripts in with the square brackets []? Yes, they do seem to be a bit off.
Edit: this is my post where I can paste my code...
