DIY current switch?
first let me say I like the forums I have read some interesting stuff and am glad to be here.
now for my question could anyone help me out I need to build a current switching switch that I can place around a AC hotwire that will simply open and close a connection when the hot wires is powered. I hope this makes sense.
Yonubear
Yonubear
yonubear
thanks,
yonubear
will this work since it is only rated at 5amp as the circuits they are going on handle up to 15 http://www.ebay.com/itm/0-5A-Input-Current-Transformer-Sensor-TA12L-200-2000-1-/300669855404?pt=LH_DefaultDomain_0&hash=item460151e6ac
yonubear
That should probably work as an on/off indicator. It may even put out enough current to drive a very low power relay. Need the data sheet to be sure though.
Essentially correct but it acts as a current transformer. Typically they have something like 2000 turns of wire on the inductor. In a perfect universe that would mean that a 2 amp current on the wire in the middle would produce 1/2000 amps or 1 mA on the inductor wire. The output voltage would depend on the load. If you connected a 1K resistor as a load the output voltage would be 1V.
