Problems moving an array to a new cog
I am trying to move an array address to a new cog. My code works without starting a new cog, so I know it has to do with trying to move the address of the array. The array I am dealing with is 50 longs.
If I change the addr in the if statement to the variable name, it works ok, so I know it has to do with passing the address. Is there a different way I should pass the address? Eventually I will move this part to its own object.
I left out a the complicated part of the code because it isn't commented yet, and just complicates it...
Thanks in advance!
Var long stack[500] long LEDstrip1 PUB Main | i, r cognew (sendLED(@Ledstrip1), @Stack) PUB sendLED(addr) | i, t repeat i from 5 to 9 If (addr[t] & |< i) outa[PinLEDdata]~~ else outa[PinLEDdata]~ more code goes here...
Thanks in advance!
Also, you mention 50 longs, where are they? If addr is the address of a long array then long[addr][idx] should be used (idx = 0..49).
I did try that earlier and it didn't work. I did try again with a few different things, and still couldn't figure the syntax of it out.
-Mike G
Forgive me here, but what do you mean by unsigned?
I attached the file I am working with...it isnt commented out, but should be pretty easy to see the idea of what I am doing.
Basically, I have a strip of 50 LEDs that use the LPD6803 IC. I am trying to build something that will allow me to chase them, and change colors, etc. Basically, every long in the variable controls one LED. 5-bits are red, 5-bits green, 5-bits blue. I am hoping when I am done I can be able to shift bits left, right, etc to chase, or just set the array to all one number to make a steady color.
If I am over complicating this and there is a much simplier way, please point it out. I am fairly new to data and playing with this LED strip to try and learn more about managing data like the sparkfun LED strip...
kuroneko - I did get yours to work... And read up on what I was doing wrong...
Mike - I tried yours just because I wanted to learn more about how you did it... And found a new problem. I can't get my waitcnt to work, even in the simplest form.
when I use the 1/2 second, I get no delay, when I use the 1 second, it doesn't go on. I checked and the crystal is ok... Wondering if it is a problem with the cog?
On a side note, I am still haveing problems actually making a new object and getting the memory address to move to the object.
Now I just need to figure out the waitcnt problem... I have been looking at the book and appears to be the right syntax, however it locks the prop up when I use the command...
THANKS FOR THE HELP!
