My first PropGCC attempt, a CW keyer
pinedust
I used SimpleIDE on a Ubuntu 10.04 64 bit system along with my Gadget Gangster USB.
It works great, and what better solution for my home brew iambic key?
I am very impressed with the work and progress on both the compiler and SimpleIDE. I look forward to updates and enhancements as both continue to mature, but they are very usable now.
Mostly I wanted to try out the IDE itself, cog threads and synchronization with locks, but this little project let try out quite a few things. I am a little fuzzy on coming up with the stack size though.
Any comments are appreciated.
Jim, W
Jim, W
Nice code!
For COG threads stack size 16 is required to save call contexts (R0-R14 & SP).
You probably need to multiply that size by the number of function levels called by the COG thread.
I'll be posting updated packages next week.
--Steve
In an embedded system making sure you've properly planned memory is always one of the biggest challenges.
I don't know if there are any more established mechanisms to do this, but I've always done something like the following. Note that I just included relevant snippets from your program; to test this yourself, you have to integrate it back into your program:
Things to note:
- For testing, use a much bigger stack size than you think you need.
- Fill the stack with a known pattern.
- Run your program, exercising the stack to what you believe is its maximum (your program just does one thing, so we just wait 10 seconds).
- Scan the stack looking for entries that changed from the known pattern (this scheme can be off an entry or two if your program uses the known pattern in its local variables)
- I always put a guard before and after the stack in case I passed the stack end address incorrectly.
In your case, the answers came up like this:
I played with it today, all kinds of various values, funny thing, I could never get it to fail. I even set the stack size to 0 and everything worked,
The program acted as it should and I was still able to produce recognizable morse, I have no idea what was going on internally though, I will probably see things happen as I add more. I wish everything was like this... failing at making software fail.
I will continue experimenting and learn what I can, that is the fun in this, right?
DEADBEEF, I haven't seen that in a while,
Oh, what do I need to do to make a printf work from within a cog thread? I tried inside and outside of locks but never got it to work. The only thing I was able to do was set a variable and print it from the calling, or original cog. It works, but was just wondering.
If your stack is too small, the program is still using the stack; it's just overwriting other memory. It's surprising how often programs that smash memory seem to work properly - sometimes I've found memory problems that have been in production for years with no (seemingly) ill effect. However, if you program is stack-bashing, then your program will tend to be unstable, and any "strange" and "unexplainable" bug is most likely the fact that your stack is improperly sized.
Could you post your code that tries to printf within the thread so we can see what you're trying to do?
There is an LED on P20 that lights when it should, when P16 goes low (no longer than 1/4 second), but I never see the message, "Hello".
I added a loop in main().
In the main() loop, the led goes on and off as expected and the count is printed out. When I drop P16 to low, not only do I not see the output "hello", the loop quits displaying the output from the count printf. The two LEDs continue to operate normally.
if I comment out the printf("hello\n"); statement, the main() loop continues to output the count regardless.
I hope I am making sense.
I am using LMM and not Simple printf.
I dropped pin 16 after the count of 3 was displayed, at that point the LEDs continued to work normal but no printf output of any kind.
When I run your program, the "hello" from the cog gets printed as gibberish! By default, you're using the SimpleSerial driver. It doesn't require an extra cog, but it is a littler bigger in code size and is not thread safe.
Instead, use the FullDuplexSerial driver. It's smaller in code size, but it does most of its work in a separate assembly-language cog. It's thread safe and your program will work as expected. Just include this after your existing includes and before your code:
Note that the STACK_SIZE of 16 is a bit more suspect when using printf; if I were you I'd set it to a bigger size and recheck the stack size requirements.
- Ted
I will use the code you gave earlier for getting a handle on stack size too.
Thanks again!
