Broken Stamp
Okay, so i think I broke my BS2, I use it with my BOE. One time I had to take the BS2 out of the IC socket for breadboard use. I accidentally broke the pin of Pin 7. At first, I thought I could live without pin 7. So I tried it with MACBS2, and I got nothing. I went on a PC and used the Official basic stamp software. Nothing. So (stupidly) I tried to solder a small piece of wire onto the solder pad on pin 7 so it could connect to the IC Socket. When I tried to solder it, the whole pad fell off. I cant find the pad. I see a small piece of stranded wire where the pad used to be. I try to plug in one end of a BreadBoard jumper into Pin 7 on the IC socket, and connect the other end to the small piece of wire. and no dice. Have I damaged the PBASIC interpreter? WIll I have to spen another $50 on a BS2? Helpme please!!!!!!
Here are some Pics:
Here are some Pics:
You should be able to live without pin 7 as that correspond to pin 5 when programming. I'm not sure why your stamp isn't working, but that pin being missing isn't the reason.
Stamps generally refuse to be identified when there's no power or there's something wrong with the serial connection to the PC (or Mac). Check your power source. Check your cables. If you're using a USB to serial adapter with a serial BOE, check that. Remember that MacBS2 won't run under Lion (at the moment ... it will be fixed sometime soon).
Unplug everything from the Board of education.
Use new batteries.
Check the voltage at the stamp to make sure it is five volts.
Check for shorts in the breadboard.
Use a new USB cable.
Re-install the drivers.
Odds are it is something simple so look for something you've overlooked.
