Dimming Lights Update — Parallax Forums
jagrifenjagrifen Posts: 36
edited 2012-03-30 06:40 in Propeller 1
There was a great article in Nuts and Volts a few years ago that showed how to create an 8 channel dimmer using the Parallax S/X chip. I was wondering if anyone has tried to rewrite this program for the propeller. I found a great object that begins to do what I am looking for but it only supports one channel. Ultimately I want to control 24 channels. Any help would be greatly appreciated.
Thanks!
  • jmgjmg Posts: 15,200
    edited 2012-03-22 20:37
    Doesn't the DMX512 handle this ?
  • JonnyMacJonnyMac Posts: 9,644
    edited 2012-03-22 20:59
    I'm working on a four-channel version for EFX-TEK (the FC-4+). It has ports for TTL serial IO and RS-485 (DMX or any other protocol that runs on '485). The board has passed the initial tests; I'll be finalizing the phase dimmer next week.
    BTW... my N&V project was an eight-channel variant of the original EFX-TEK FC-4 (which I also designed and coded).
  • DynamoBenDynamoBen Posts: 366
    edited 2012-03-22 21:35
    I have an open source project that might be helpful. Schematics and code are there, let me know if you have questions. http://code.google.com/p/propcontroller/
    I suspect this sample code will be the most useful. http://code.google.com/p/propcontroller/source/browse/#svn%2Ftrunk%2FProjects%2FDMX_128
  • jagrifenjagrifen Posts: 36
    edited 2012-03-23 10:35
    Thanks for the help everyone! Ben, I think what I am trying to do is very similar to what your project offers. Luckily my deadline just got extended so I have a bit of time to play around.
    edited 2012-03-29 19:31
    I was fighting a noise problem on my AC input -- fixed it with some code. The attached 4-channel code works for me, but to be honest I don't have a lot of time on it (hence I haven't moved it to ObEx yet). After some testing of incandescent lamps I'm going to add an optional curve to improve the output. Adding more channels will not be a problem if you need more.
    Note: Code updated 3/30 per suggestion from ke4pjw
  • ke4pjwke4pjw Posts: 1,278
    edited 2012-03-29 20:56
    jagrifen wrote: »
    Thanks!
    I used that exact article as a guide to make 16 channel dimmers. I simply padded the the "accumulators" with a value of $FFFF_FF00 so that it would roll over when it reached 256. Works great!
    http://www.youtube.com/watch?v=oqrkTCQr85c
    edited 2012-03-29 21:14
    Excellent idea and I can confirm that it works great. Thanks for the tip!
    Awesome! I'll have to try playing around with that.
