USB datalogger not working
HI,
I just tried to update my datalogger using file ftrfb.fdt which i got from http://www.ftdichip.com/Firmware/Precompiled.htm but i dont think it worked.
now nothing seems to work, no lights come on. cant communicate with it :S
is there some way to fix this????
thanks
si
PS any quick reply will be very appreciated and will earn many good karma points!
thanks
si
i renamed it then put out on usb. Plugged it in, switched it on then...nothing!
Have I somehow fried it? How would I go about the other method mentioned in the pdf?
Thanks again
si
Could someone do me a great big favour and test this code (or help me where it has gone wrong)
It is based on code talked about in these forums:
http://forums.parallax.com/showthread.php?112872-Datalogger-BS2-or-SX-(-115200-)
http://forums.parallax.com/showthread.php?135280-USB-Mem-stick-datalogger-w-BS2-upgraded-firmware-initialization-question
Code:
An upgrade can be done, as you probably know, by copying a file to a memory module and placing it in the drive or alternatively making a hardware connection and using a PC utility to upgrade the firmware. If the firmware was not right and your datalogger will not read from a memory module then you may have to go the PC utility route to recover. Most memory modules have an led to indicate read and write activity, if you plug in a memory module do you see any activity on the led. Try powering up the logger with a module inserted and look for led activity.
Jeff T.
Yes the Data logger was working, i upgraded to get the latest firmware as suggested in previous forums.
Nothing seems to work, none of the LED light up. I tried to downgrade the firmware via USB but to no avail!
Si
Section 4 describes the procedure and at minimum you would need the TTL 3.3v UART cable.
You may or may not think it is worth the trouble to buy a cable, and even then you don't know for sure whether that will fix the problem.
If it were me I would buy the cable ( I actually have one ), they run around the $20 mark. If you fix your datalogger you will feel it was worthwhile and you will have learnt by it. If you don't fix the datalogger the cable is still a good tool to own ( USB to 3.3v serial ) and again you will learn by it although the feeling might not be the same as fixing it, but I would bet there is nobody on this forum that hasn't accidently rendered some piece of electronic device useless.
Jeff T.
