BS2 is not being detected
HI,
My Bs2 has recently stoped being detected by the stamp editor software. both loopback and echo say yes in the identify window. i am using a brand knew 9v alkaline battery, and a newlink USB to serial adapter to connect my pc to the pcb. is it a problem with the cable, or could my bs2 have been damages, eg by esd? as i say it has worked fine in the past.
thanks
thanks
Do you see any bits of metal or solder between the pins? Is the EEPOM surface mount and soldered down or a DIP in a socket? If it is in a socket you could remove it and see if the voltage between 21 and 23 returns to normal.
