Eddie Control board - no encoder pins?
Was getting through my first assembly and going to the point where I connect the Position Controller to the encoder pins on the control board... but the control board I received does not have them. I see them in the diagram in the documentation between the ADC and IO pins - but there's nothing there on my board.
Any suggestions on what to do with the position controller cable?
Thanks!
Thanks!
http://www.parallax.com/portals/0/downloads/docs/prod/robo/eddie/220-28990-EddieControlBoardRevA.pdf
Hope this helps,
Robert
-Dan
The encoders are built into the wheel/motor assembly. The cables are the smaller three conductor. It looks like they plug into 11 and 12 on the "I/O" connector
Jim
EDIT: looking at the schematic, J7 is the I/O connector and there was supposed to be a J8 for the encoders, but it looks like they incorporated the I/O's and encoders on the one connector (J7).
Publison is right, we did have a separate I/O connector on Rev A of the Eddie Control Board. However, as those pins were really just GPIO pins, we didn't want users to think that they could only be used for encoders. So we incorporated them all into the J7 connector. The pin assignments remain the same however, pin connection is the same, P11.
Thanks for pointing this out, I'll make sure the documentation gets updates ASAP.
Cheers,
Jessica
