String + String
G'day, I know that this is quite a basic question, but it has been stumping me, how can I add 2 strings together easily, or append a charecter to the end of a string?
John
[EDIT] To clarify, add 2 VARIABLES (String) together.
John
Also code for appending to a string.
It is a bit more difficult to work with strings in Spin compared with some other languages so it is ok if you are finding it hard.
The propeller does not have dynamic memory allocation. This means when you want to add/append/concatenate strings you have to be sure that the buffer used to hold the result is big enough in advance!
@Dr_Acula:
Actually the basic equivalent of what you do inside the stringConcatenate-function is:
B$ = B$ + C$
return B$
The A$= part you mention is outside of the stringConcatenate and is optional.
stringConcatenate( @string1, @string2 ) would ommit the A$-part but still work and produce the same result
str_ptr := stringConcatenate( @string1, @string2 ) would do it A$=-style - but there is no point in doing this assignment.
With what I said in the first sentence something like this is a BUG:
str_ptr := stringConcatenate( string("Test"), string(" concatenation") ) because string("Test") does not reserve more bytes than needed for "Test" and the concatenation would overwrite bytes it should not touch. (using string() for the second parameter is fine!)
Yes, I agree you need to break down A$=B$+C$ into two parts A$=B$ and then A$ =A$+C$.
To add to the link to that string handling code (which is Kye's string handler plus a few Basic like instructions I added), in your "main" program you need to declare some generic string variables:
move a 'fixed' value into a string variable with
str.copy(string("hello"),@lineoftext1) ' copy fixed value into a stringand then everything is referenced with the @ symbol. This was a whole lot of demo code I used to test strings. It is all commented at the moment but you can see some of the ideas how to manipulate strings
'printstring(@lineoftext1) ' testing string functions 'str.left(@lineoftext1,@lineoftext2,3) ' find leftmost characters in a string 'printstring(@lineoftext2) 'str.trimstring(@lineoftext1) 'printstring(@lineoftext1) 'str.trimstring(@lineoftext1) 'str.mid(@lineoftext1,@lineoftext2,4,2) ' find middle characters in a string 'printstring(@lineoftext2) 'printstring(str.integertodecimal(str.len(@lineoftext2),5)) 'str.copy(string("hello"),@lineoftext1) ' copy fixed value into a string 'printstring(@lineoftext1) 'str.str(@lineoftext1,55) ' decimal to string with no leading zeros 'printstring(@lineoftext1) 'str.stringfill(@lineoftext1,10,65) 'printstring(@lineoftext1) 'str.str(@lineoftext1,1234)' convert to string 'str.str(@lineoftext1,str.decimaltointeger(@lineoftext1)) ' convert back 'printstring(@lineoftext1) ' str.left(@lineoftext1,@lineoftext2,str.len(@lineoftext1)-4) ' remove extension ' printstring(@lineoftext2) ' print it outKye's string object has an official name if you want to use the .spin object. See attachment.
Summary of the string instructions below. Most are Kye's and follow the format "instruction, destination, source" but some of the ones I wrote follow the Basic syntax of "source, destination".
Kye's "buildstring" has some additional tricks like being able to handle backspace.
PUB buildString(character) '' 4 Stack longs PUB builtString(resetString) '' 4 Stack Longs PUB builderNumber '' 3 Stack Longs PUB builderFull '' 3 Stack Longs PUB stringCompareCS(characters, otherCharacters) '' 5 Stack Longs PUB stringCompareCI(characters, otherCharacters) '' 9 Stack Longs PUB stringCopy(whereToPut, whereToGet) '' 5 Stack Longs PUB stringConcatenate(whereToPut, whereToGet) '' 5 Stack Longs PUB stringToLowerCase(characters) '' 4 Stack Longs PUB stringToUpperCase(characters) '' 4 Stack Longs PUB trimString(characters) '' 8 Stack Longs PUB tokenizeString(characters) '' 8 Stack Longs PUB findCharacter(stringToSearch, characterToFind) '' 5 Stack Longs PUB replaceCharacter(stringToSearch, characterToReplace, characterToReplaceWith) '' 11 Stack Longs PUB replaceAllCharacters(stringToSearch, characterToReplace, characterToReplaceWith) '' 17 Stack Longs PUB findString(stringToSearch, stringToFind) | index, size '' 7 Stack Longs PUB replaceString(stringToSearch, stringToReplace, stringToReplaceWith) '' 13 Stack Longs PUB replaceAllStrings(stringToSearch, stringToReplace, stringToReplaceWith) '' 19 Stack Longs PUB integerToDecimal(number, length) '' 5 Stack Longs PUB integerToHexadecimal(number, length) '' 5 Stack Longs PUB integerToBinary(number, length) '' 5 Stack Longs PUB decimalToInteger(characters) | sign '' 10 Stack Longs PUB hexadecimalToInteger(characters) | sign '' 10 Stack Longs PUB binaryToInteger(characters) | sign '' 10 Stack Longs PRI ignoreCase(character) ' 4 Stack Longs PRI ignoreSpace(characters) ' 4 Stack Longs PRI checkSign(characters, signAddress) ' 5 Stack Longs PRI checkDigit(characters, low, high) ' 5 Stack Longs PUB endsWithString(stringToSearch, stringToFind) '' 12 Stack Longs PUB Left(Source, Destination,Number) ' returns the left number of characters PUB Len(Source) ' returns the length of the string PUB Mid(Source,Destination,Start,Number) ' returns strings starting at start with number characters PUB Copy(Source,Destination) ' reverse order to stringcopy. Can also use to create strings eg copy(string("test"),@lineoftext1) PUB Str(Destination,Number) | n' convert a number to a string representation. Uses Basic syntax, ie leading character is a space if +ve, and is - if negative PUB Stringfill(Destination, Number,AsciiValue)' fill string with a string, eg 3,65 is"AAA" and 2,32 is " " PUB Instr(Source,AsciiValue) | j ' find asciivalue in Source. Returns 0 if not found
