Boe-Bot Ping more often
Hello, new guy here as always. I recieved my boe bot with ping sensor and bracket recently and all is going well. The boe bot roams the house well enough. My question is how to pulse the ping sensor while the boe bot is in motion. I have changed the counter in the code so the sensor will ping more often yet its only once per forward cycle...(if that makes sense..) I have also shortened the forward pulse so that it stops more often to scan. On forward pulses over say 75 the boe bot will run into the wall and will not stop until the cylce is complete and then scan. I understand the stamp only does one command at a time, just really fast. Id like to make it like the parallax videos where you can see the ping sensor constantly pinging without so called stoping... Also I would like to have it stop before it hits the wall. I have googled and searched the forums to no avail. I apologize ahead of time if I have missed something. Thank you for any responses.
' ========================================================================= ' ' ' {$STAMP BS2} ' {$PBASIC 2.5} ' -----[ I/O Definitions ]------------------------------------------------- Piezo PIN 4 ' Piezo Speaker RightServo PIN 12 ' Right Servo LeftServo PIN 13 ' Left Servo PingServo PIN 14 ' PING))) Servo Ping PIN 15 ' PING))) Sensor ' -----[ Variables ]------------------------------------------------------- pulseCount VAR Byte ' Used For Measuring Turns distance VAR Word ' Current Distance Of Object oldDistance VAR Word ' Old Distance Value counter VAR Word ' PING))) Cycle Counter task VAR Nib ' Current Task ' -----[ Initialization ]-------------------------------------------------- FREQOUT Piezo, 2000, 3000 ' Signal Program Start/Reset ' -----[ Program Code ]---------------------------------------------------- Main: DO counter = counter + 1 ' Increment Passive Counter IF counter > 1 THEN ' Wait For 1 Servo Pulses GOSUB Ping_Out ' Activate PING))) ENDIF IF (distance > 30) THEN ' Is Object Farther Than 30 cm? GOSUB Forward_Pulse ' If Yes Go Forward ELSE GOSUB Ping_Around ' Otherwise Scan For Clear Path ENDIF LOOP ' -----[ Subroutines ]----------------------------------------------------- Forward_Pulse: ' Send A Single Forward Pulse FOR pulseCount = 1 TO 75 PULSOUT PingServo, 765 ' Ping Servo Forward Pulse Value PULSOUT LeftServo, 850 ' Left Servo Forward Pulse Value PULSOUT RightServo, 650 ' Right Servo Forward Pulse Value PAUSE 20 ' Refresh Delay NEXT RETURN ' ************************************************************************* ' * USE THE APPROPRIATE PULSOUT VALUES TO MAKE YOUR BOE-BOT TURN LEFT 90 * ' * DEGREES. USE THE SAME VALUE AS ABOVE FOR THE PING))) BRACKET SERVO. * ' ************************************************************************* Turn_Left: ' Left Turn, About 45 Degrees FOR pulseCount = 0 TO 7 ' Number Of Pulses To Turn PULSOUT PingServo, 765 ' Ping Servo Forward Pulse Value PULSOUT LeftServo, 650 ' Left Servo Left Pulse Value PULSOUT RightServo, 650 ' Right Servo Left Pulse Value PAUSE 20 ' Refresh Delay NEXT RETURN ' ************************************************************************* ' * USE THE APPROPRIATE PULSOUT VALUES TO MAKE YOUR BOE-BOT TURN RIGHT 90 * ' * DEGREES. USE THE SAME VALUE AS ABOVE FOR THE PING))) BRACKET SERVO. * ' ************************************************************************* Turn_Right: ' Right Turn, About 45 Degrees FOR pulseCount = 0 TO 7 ' Number Of Pulses To Turn PULSOUT PingServo, 765 ' Ping Servo Forward Pulse Value PULSOUT LeftServo, 850 ' Left Servo Right Pulse Value PULSOUT RightServo, 850 ' Right Servo Right Pulse Value PAUSE 20 ' Refresh Delay NEXT RETURN ' ************************************************************************* ' * USE THE APPROPRIATE PULSOUT VALUES TO MAKE YOUR BOE-BOT MOVE BACKWARD * ' * WHILE THE PING))) IS FACING FORWARD. * ' ************************************************************************* Back_Up: ' Back Up FOR pulseCount = 0 TO 40 ' Number Of Pulses To Backup PULSOUT PingServo, 765 ' Ping Servo Forward Pulse Value PULSOUT LeftServo, 650 ' Left Servo Backup Pulse Value PULSOUT RightServo, 850 ' Right Servo Backup Pulse Value PAUSE 20 ' Refresh Delay NEXT RETURN Ping_Out: ' PING))) counter = 0 ' Reset Passive Delay Counter LOW Ping ' Force PING))) Line Low PULSOUT Ping, 5 ' Activate PING))) Pulse PULSIN Ping, 1, distance ' Receive Return Pulse distance = distance ** 2257 ' Calculate Distance RETURN Ping_Around: ' Start 180 Degree Pan-Scan counter = 0 ' Reset Passive Delay Counter oldDistance = 30 ' Current Old Distance Values task = 0 ' Current Task Priority ' ************************************************************************* ' * USE THE APPROPRIATE PULSOUT VALUE TO MAKE YOUR PING))) * ' * TURN 90 DEGREES LEFT. * ' ************************************************************************* FOR pulseCount = 0 TO 20 ' Number Of Pulses To Spin LOW Ping ' Force PING))) Line Low PULSOUT PingServo, 1260 ' Ping Servo 90 Left Pulse Value PULSOUT Ping, 5 ' Activate PING))) PULSIN Ping, 1, distance ' Receive Distance Value PAUSE 20 ' Refresh Delay NEXT distance = distance ** 2257 ' Calculate Distance In cm IF distance > oldDistance THEN ' Is distance > Last Clear Path oldDistance = distance ' Update oldDistance Value task = 1 ENDIF ' ************************************************************************* ' * USE THE APPROPRIATE PULSOUT VALUE TO MAKE YOUR PING))) * ' * TURN 45 DEGREES LEFT. * ' ************************************************************************* FOR pulseCount = 0 TO 20 ' Number Of Pulses To Spin LOW Ping ' Force PING))) Line Low PULSOUT PingServo, 850 ' Ping Servo 45 Left Pulse Value PULSOUT Ping, 5 ' Activate PING))) PULSIN Ping, 1, distance ' Receive Distance Value PAUSE 20 ' Refresh Delay NEXT distance = distance ** 2257 ' Calculate Distance In cm IF distance > oldDistance THEN ' Is distance > Last Clear Path oldDistance = distance ' Update oldDistance Value task = 2 ENDIF ' ************************************************************************* ' * USE THE APPROPRIATE PULSOUT VALUE TO MAKE YOUR PING))) * ' * TURN 45 DEGREES RIGHT. * ' ************************************************************************* FOR pulseCount = 0 TO 20 ' Number Of Pulses To Spin LOW Ping ' Force PING))) Line Low PULSOUT PingServo, 400 ' Ping Servo 45 Right Pulse Value PULSOUT Ping, 5 ' Activate PING))) PULSIN Ping, 1, distance ' Receive Distance Value PAUSE 20 ' Refresh Delay NEXT distance = distance ** 2257 ' Calculate Distance In cm IF distance > oldDistance THEN ' Is distance > Last Clear Path oldDistance = distance ' Update oldDistance Value task = 3 ENDIF ' ************************************************************************* ' * USE THE APPROPRIATE PULSOUT VALUE TO MAKE YOUR PING))) * ' * TURN 90 DEGREES RIGHT. * ' ************************************************************************* FOR pulseCount = 0 TO 20 ' Number Of Pulses To Spin LOW Ping ' Force PING))) Line Low PULSOUT PingServo, 300 ' Ping Servo 90 Right Pulse Value PULSOUT Ping, 5 ' Activate PING))) PULSIN Ping, 1, distance ' Receive Distance Value PAUSE 20 ' Refresh Delay NEXT distance = distance ** 2257 ' Calculate Distance In cm IF distance > oldDistance THEN ' Is distance > Last Clear Path oldDistance = distance ' Update oldDistance Value task = 4 ENDIF ON task GOSUB Task0, Task1, Task2, Task3, Task4 distance = 50 ' Prevent Scan From Looping RETURN Task0: ' Forward Was Clearest Path GOSUB Turn_Right ' This Could Mean Narrow Path GOSUB Turn_Right ' So We'll Turn Around GOSUB Turn_Right ' You Can Change The Behavior GOSUB Turn_Right ' Of Any Of The Tasks RETURN Task1: ' 90 Degrees Left Was Clearest GOSUB Turn_Left GOSUB Turn_Left RETURN Task2: ' 45 Degrees Left Was Clearest GOSUB Turn_Left RETURN Task3: ' 45 Degrees Right Was Clearest GOSUB Turn_Right RETURN Task4: ' 90 Degrees Right Was Clearest GOSUB Turn_Right GOSUB Turn_Right RETURN
The other way I can see is to not simply react to close objects but instead actually store the value you get from your PING in front of you and then use that value to decide how far to drive forward conservatively before you stop and look around again. This way you don't have to run the PING between servo refreshes instead you use it to measure out your movement before-hand. Then you stop look around and if the forward distance is less than your threshold you scan for a new direction to move.
Glad you got an answer you're looking for :thumb:
-Matt
