Chevy Volt Teardown Videos
For those who were wondering...
http://www.designnews.com/document.asp?doc_id=240499&cid=Newsletter+-+Gadget+Freak
-dan
http://www.fool.com/investing/general/2011/02/20/chevy-cruze-eco-58-mpg-no-hybrid-magic.aspx
mikev
GM certifed master tech
Plus, I'll throw in a Basic Stamp and some relays...
How about a flame-throwin' BoeBot? Sorry Ken!
I drive past "Electric Vehicle Drive" and GM's development center in Torrance almost every day and wonder what cool things are going on inside.
And occasionally I drive past Honda's R&D center (also in Torrance) where the Asimo robots are maintained, and wonder how I can get in there.
I've seen a LOT of negative comments on the internet about the Volt from automotive types...
And I have noticed these same people are good at "mechanical things", but don't know much at all about electrical/electronic things.
So I'm thinking the basis for these negative comments is mostly due to the fact it is electric? And they can't "modify" the engine to make it have more power, switch out to a fancy looking air filter, super duper spark plug wires, or other changes???
(Of course the people HERE could make all sorts of electrical modifications...
Pulg wires and carbs make way for cracked firmware and larger MOSFETS ( or IGBTs)
its gonna be EEs and the geeks with soldering guns that will get a Volt to do a 5 Sec 1/4 mile .. not many mike and joe at pepBoys .
sadly a 300+ volt bat pack is more lethal then a tank of gas in the hands of a weekend warrior .
I have seen a 36V Golf cart pack get shorted by some noobs here at the EET lab . YIKES !
Its Kinda funny as my senior project I have picked is a tri Fuel Hybrid golf cart ..
Propane CNG and Gas .. .
just as a Volt does . its a Series Hybrid .. so its all EV drive .. but has a Aux power off a IC to get a charge on the go .
Peter
I'm sure someone will come out with Neon colored "Oxygen Free, Molecular Aligned, Coherent Electron Flow" wiring to replace the factory wiring.
C.W.
Are you saying GM only gives it's employees a $1000 discount? Even Walmart does 10%...
