learning asm have a quick question
I'm trying to work with I/O ports in assembly and I've run into a problem.
I can set single pins with 'or outa, myregister' no problems, but I need to change the direction of P8-P15 to output, place a byte on those pins, then after a delay turn the direction back to input only on P8-15
What I tried to do was:
mov dira, dbusout 'make P8-P15 output
or outa, #$55
nop
mov dira, dbusin 'change pins back to input
dbusout long $FF<<8
dbusin long $00<<8
I'm totally missing something. Also, I've read a few of the "beginning asm for the propeller tutorials" but I'm looking for something that can explain controlling the ports a little better. I've been using the ATmega chips and defined 8 bit ports. I just need a little nudge in the right direction on this.
Vince
or outa, #$55
nop
dbusout long $FF<<8
dbusin long $00<<8
Vince
Note that by using or and andn you do not upset other pins -- this is a good habit to get into as your programs become more complex.
mov mask, #%1111_1111 shl mask, #8 mov mybits, #%1010_1010 shl mybits, #8 andn outa, mask ' clear old bits or outa, mybits ' write new bits or dira, mask ' make p8-15 outputs ' do stuff andn dira, mask ' make p8-15 inputsBTW, you should use the [ code ] and [ /code ] tags (sans spaces) around code you want to post.
Also, take a look at the andn command. It will allow you to use the same mask for setting the pins to input as you used for setting them to output.
I'm going to try the 'or' instead of the mov. I was changing direction on my other pins, duh. Great help guys. Let you know how it goes. Oh, I'm using a LA to see the results, so I can see ns results if I program the ports correctly.
Vince
