Gps project
Hi
Am new to electronics I want to record gps data on a pic
GPS communication protocol - UART <-
*Baud rate - 4800 bps
*Updates every 1second
*Communication format NMEA
*logic level TTL
PIC18F2420
communication protocol - MSSP/ EUSART
EUSART can be configured to UART
USB ( POLULU, active robots)
data transfere rate - 921.6 kbps max
How do I create the code please help my programming skills are minimum
*logic level TTL
PIC18F2420
Is this a Parallax GPS you're using?
It sounds to me like you are jumping into the deep end. It might be better to use a microcontroller with sample code available that already does roughly what you want. The site below shows how to use the GPS on three popular microcontrollers.
https://sites.google.com/site/parallaxinretailstores/home/gps-module-pmb-648-sirf
