Controlling High Current LED PWM
I am going to be undertaking a large LED Control project, I need to control 9 loads of LEDs of different colors, each color is going to be drawing about 200-450watts. Any recommendations on what to use to control this? Just a 60a transistor? Just dont know if there are any better solutions, IE triggering multiple of them simultaneously from the same output pin.
Jimmy
Jimmy
I fully concur, you also need a driver to protect the microcontroller from switching transients passed back via the gate-drain capacitance I suspect - protection circuitry at this current level is mandatory really - you don't want a blown MOSFET to fry all the rest of the electronics.
EMI is also an issue I suspect.
You might want to consider using opto isolators to protect the prop from magic smoke release!
Jim
Lawson
