Source for white plastic 8.5"x11" printer sheets?
I've seen several places carry plastic transparency film for laser and inkjet printers that can work well for printing circuit board traces and optical encoders. Does anyone happen to know of a source for similar sheets but in a white plastic that would be opaque? I would like to get some for printing reflective encoder wheels with a laser printer that will be durable. I've seen smaller plastic sheets for making labels and ID cards but haven't found full 8.5" x 11" sheets like the transparency film.
Another option would be the higher end water/smuge proof papers for Laser printers. I just want to use something that will last.
If you have any suggestions or sources please let me know.
Robert
Robert
It is a polyester plastic film that is textured for inkjet on one side, and it holds brilliant sharp colors. After printing I laminate the inked side under a clear, thin, pressure laminating film, and that makes it quite water-wickproof. I use it for labeling breakout terminals and such things. It is meant for inkjet or dye printers, but I have found it also works fine in a color laser printer.
Rite in the Rain, a waterproofed paper product.
Robert
Some of their paper is fully synthetic (good for what you want), and some is kind of plastic in the middle with paper on the outside
Thank You!
Robert
So far the testing is working out well and I think I'll be using this for other encoders as well.
Robert
Jim
Hello Jim,
For the particular robot these are going on the resolution isn't that high. They are being mounted directly to the wheel. It will help keep track of how far it has gone and what direction. I will be doing some higher resolution ones as well but may need to use different IR sensors. An example of the encoders is attached here:
encoderwheel_quadrature.pdf
Robert
Just an FYI: You don't need two separate tracks to make a quadrature encoder. Just position both sensors over one track, such that their positional relationship varies by n + 1/4 full cycles of the bar pattern.
Hello Phil,
I was originally going to use a single track. The main issue is the positioning of the sensors. When using a single track you have to adjust the position of each sensor and it is then fixed to that particular encoder. Since I mount the sensors on a protoboard I am usually limited by the .100" spacing. With that I need to get the sensors close and then make the mounting adjustable to slide in and out from the center of the encoder to get the spacing right. Frankly it can be a PITA. Having two tracks does seem to have a big advantage as long as there is room for both tracks. With two tracks I just position each sensor inline. The only spacing is to make sure each one is centered over each track. It eliminates the need for any further adjustment. With this I can easily change the resolution of the encoder by just printing a new one and no longer need to adjust the sensors! One less thing to mess with.
Now if I need to use the optical encoder sensors that already have both sensors in one then I would just print a single track with a resolution to match. I'll use whatever method works best for the task at hand.
Robert
for as many different useful values of m as possible, where j is also an integer.
