Serial LCD not obeying commands to start at 0,0 and 1,0
I have had a heck of a time trying to get a serial LCD connected to a BOE and BS2 to place the characters where I want them on the LCD. I just need to be able to have the word "Humidity" displayed at 0,0 and then the actual value of humidity displayed immediately after that. It keeps writing and wrapping instead of placing them at the same place on the LCD and overwriting with new values. Here is my code:
Any ideas? I have changed the "LcdLine1", and "LcdLine2" constants to hex and back with no difference in the result.
' {$STAMP BS2}
' {$PBASIC 2.5}
' RelativeHumidityReading.bs2
' Displays relative humidity in the Debug Terminal or the Parallax Serial LCD.
index VAR Word
Humaverage VAR Word
LCD PIN 0 ' Serial output to LCD
time VAR Word
humidity VAR Word
LcdBaud CON 16780 ' Baud rate of LCD
RHconstant CON 11398 ' Relative Humidity Constant * 10
LcdCls CON $0C ' Clear LCD (use PAUSE 5 after)
LcdCR CON $0D ' Move pos 0 of next line
LcdBLon CON $11 ' Backlight on
LcdBLoff CON $12 ' Backlight off
LcdOff CON $15 ' LCD off
LcdOn1 CON $16 ' LCD on; cursor off, blink off
LcdLine1 CON 128 ' Move to line 0, position 0
LcdLine2 CON 148 ' Move to line 1, position 5
HIGH Lcd ' Setup serial output pin
PAUSE 100
SEROUT Lcd, LcdBaud, [LcdOn1] ' Initialize LCD
PAUSE 250
'SEROUT Lcd, LcdBaud, [LcdBLon] ' Turn Backlight on
'PAUSE 5
SEROUT Lcd, LcdBaud, [LcdCls] ' Clear LCD
PAUSE 5
DO
FOR index = 1 TO 100
HIGH 7
PAUSE 5
RCTIME 7, 1, time
'time = time * 10
humidity = ((time * 10) - 11398)/24
'humidity = (time - RHconstant) / 24
IF index = 1 THEN Humaverage = humidity *4
Humaverage = Humaverage */192 + humidity
NEXT
Humaverage = Humaverage/4
' Debug Display:
DEBUG HOME, "Rel. Humidity = ", DEC humidity, "%",CLREOL
' LCD Display:
SEROUT Lcd, LcdBaud, [LcdLine1, "Humidity",LcdLine2, DEC Humaverage, "%" ]
PAUSE 100
LOOP
Change
to
Set the LCD for 9600 baud (switch 1= off, switch 2= on)
I couldn't duplicate your problem exactly, but with these changes it worked fine for me.
Doc.
