Problem with Numbers object
Hi All,
First time posting here - certainly seems to be no end of brain power in this forum
I'm just starting out using my Propeller board I purchased a couple years back and have run into an issue using the numbers.spin object.
I have a number of pins attached to a small parallel LCD and have been able to print out characters from a string variable. No problems there. I have been unable to get the Num.ToStr object interface working though.
See code below:
The 'Print String' test works fine - the 'Number to string test' just prints garbage.
I've used the print string function in the parallax serial terminal and that seems to work correctly. Any ideas what's going on?
Let me know if you need more information.
Thanks..
See code below:
VAR
BYTE LCD_RS 'LCD REGISTER SELECT (0=COMMAND, 1=DATA)
BYTE LCD_RW 'LCD READ/WRITE SELECT SIGNAL (0=WRITE, 1=READ)
BYTE LCD_E 'LCD OPERATION ENABLE SIGNAL (FALLING EDGE TRIGGERED)
LONG TEST_NUMBER 'USED IN TEST NUMBERS OBJECT
LONG STRINGPOINTER 'USED IN TEST NUMBERS OBJECT
BYTE X 'INDEX VARIABLE
BYTE CHAR_INDEX
OBJ
NUM : "Numbers"
PUB Main
DIRA[0..10]~~ 'SET LCD I/O PINS TO OUTPUT
DELAY(10_000_000)
LCD_RS := 10
LCD_RW := 9
{FORMAT DISPLAY}
LCD_DISPLAY_CTRL
LCD_FORMAT
'CLEAR DISPLAY
LCD_CLEAR
LCD_HOME
{PRINT STRING TEST}
DELAY(1_000_000)
REPEAT CHAR_INDEX FROM 0 TO 9
OUTA[0..7] := TEST_STRING[CHAR_INDEX]
OUTA[LCD_RS]~~
OUTA[LCD_RW]~
OUTA[8]~~
OUTA[8]~
{NUMBER TO STRING TEST}
NUM.INIT 'INITIALIZE NUMBERS OBJECT
TEST_NUMBER := 5678
STRINGPOINTER := NUM.TOSTR(TEST_NUMBER, NUM#DEC)
DELAY(5_000_000)
REPEAT X FROM 0 TO 3
OUTA[0..7] := BYTE[@STRINGPOINTER][X]
OUTA[LCD_RS]~~
OUTA[LCD_RW]~
OUTA[8]~~
OUTA[8]~
DELAY(200_000)
REPEAT
PUB LCD_DISPLAY_CTRL
OUTA[0..7] := �001111 'CONTROL DISPLAY COMMAND
OUTA[LCD_RS]~
OUTA[LCD_RW]~
OUTA[8]~~ 'SEND ENABLE PULSE
OUTA[8]~
PUB LCD_CLEAR
OUTA[0..7] := �000001 'CLEAR DISPLAY COMMAND
OUTA[LCD_RS]~
OUTA[LCD_RW]~
OUTA[8]~
PUB LCD_HOME
OUTA[0..7] := �000010 'HOME DISPLAY COMMAND
OUTA[LCD_RS]~
OUTA[LCD_RW]~
OUTA[8]~
PUB LCD_FORMAT
OUTA[0..7] := �111100
OUTA[LCD_RS]~
OUTA[LCD_RW]~
OUTA[8]~~
OUTA[8]~
PUB DELAY(TIME)
WAITCNT(TIME + CNT)
DAT
TEST_STRING BYTE "123456789 ",0
Thanks..
Let's assume we have the following memory map. (This is only hypothetical
RAM-Address Label Content Size .. $1000 STRINGPOINTER 0 Long $1004 TEST_NUMBER 0 Long $1008 X 0 Long .. $1200 STRBUFFER 0 Byte array [13] $1201 0 .. $120D 0What does your progam do with this memory:TEST_NUMBER := 5678
RAM-Address Label Content Size .. $1000 STRINGPOINTER 0 Long $1004 TEST_NUMBER [color=red]5678[/color] Long $1008 X 0 Long .. $1200 STRBUFFER 0 Byte array [13] $1201 0 .. $120D 0[sp][/sp][sp][/sp]
STRINGPOINTER := NUM.TOSTR(...)
RAM-Address Label Content Size .. $1000 STRINGPOINTER 0 Long $1004 TEST_NUMBER 5678 Long $1008 X 0 Long .. [color=red] $1200 STRBUFFER "5" Byte array [13] $1201 "6" $1202 "7" $1203 "8" $1204 0 [/color] .. $120D 0[sp][/sp]
[sp][/sp]
RAM-Address Label Content Size .. $1000 STRINGPOINTER [color=red]$1200[/color] Long $1004 TEST_NUMBER 5678 Long $1008 X 0 Long .. $1200 STRBUFFER "5" Byte array [13] $1201 "6" $1202 "7" $1203 "8" $1204 0 .. $120D 0So, what will OUTA be in the first iteration?
[sp][/sp]
@STRINPOINTER is equal to $1000, so what whe have is
OUTA[0..7] := content of the memory location $1000 + 0 (0 coming from X) := 00
In the next iteration it would be
OUTA[0..7] := content of the memory location $1000 + 1 (1 coming from X) := 12
(if I remember right the prop is least significant byte first)
PS: Adding the missing bit here ;o)
So, @STRINGPOINTER is NOT what you want!
You want to have the content of STRBUFFER and it's following bytes.
STRBUFFER is equal to address $1200 and this value (the address itself) is stored in STRINGPOINTER. So, if you want to read from $1200 you simply say:
OUTA[0..7] := byte[ STRINGPOINTER ][ i ] which is the same as
byte[ $1200 ][ i ] or in other words "give me the content of memory location $1200 + i" which is "5"
Thank you very much - your initial explanation clued me to try the STRINGPOINTER without the '@' and it worked great
