Gps module no fix status
Hi
I am new to electronics doing a project with a gps module + pic18f2420+usb ( tracking device) my problem is that
my gps module is not getting a fix status the led is just flashing?
please help
please help
Was I just lucky in getting one that exceeds it's specs?
without hooking it to the rest of the circuit?
My older Parallax GPS takes a long time (several minutes) and needs to be outside to get a lock. I have another unit that will get a lock quickly while sitting at my desk.
I've also found a switching power regulator can interfere with a GPS unit. If you're using a switching regulator, I'd suggest using a linear regular until you're sure you GPS unit is working correctly.
Waited for 3minutes nothing, the led was just flashing. Could it be that the gps module is faulty?
The one I mentioned previously took longer than 3 minutes to get a lock. Try 10 or even 15 minutes.
How are you powering it?
There are other, newer modules that get a lock much more quickly, but as someone has pointed out, that first time you will have to wait a surprisingly long time.
