NMEA0183 parsing out of variable space
HI All,
Iḿ trying to parse to following NMEA string
Beside doing a degrees to decimal conversion (and other stuff) i also would like to output the complete string to send it via SEROUT.
As i'm chopping my way through a sample from the parallax site iḿ running into a "Out of variable space" error in the editor.
My code sofar is:
I'm a unexperienced programmer so im learning on the job here.
Beside pasing through a string i want that stamp to do a lot more but iḿ wondering if im hitting bounderies already or am i just making a huge error here.
What would be a good way to solve this?
Gr,
Ernst
$GPRMC,160056.000,A,5156.7871,N,00600.9030,E,0.00,206.54,120312,,,A*6E
My code sofar is:
' {$STAMP BS2} ' {$PBASIC 2.5} '----[ Program Definitions ]------------------------------------------------------------------------------ ' ' <desciption> '----[ I/O definitions ]---------------------------------------------------------------------------------- gpsRx PIN 0 GpsFixLed PIN 1 '----[ Constants ]---------------------------------------------------------------------------------------- n4800 CON 188 n9600 CON 84 '----[ Variables ]---------------------------------------------------------------------------------------- LatDeg VAR Byte LatMin VAR Byte LatMinD VAR Word LatSign VAR Byte LatDir VAR Byte LonDeg VAR Byte LonMin VAR Byte LonMinD VAR Word LonSign VAR Byte LonDir VAR Byte hh VAR Byte mm VAR Byte ss VAR Byte sss VAR Word DD VAR Byte MM VAR Byte YY VAR Byte status VAR Byte dest VAR Nib(2) degr VAR Byte(2) Fix VAR Byte counter VAR Nib wVal VAR Word '----[ EEPROM Data ]-------------------------------------------------------------------------------------- '----[ Initialisation ]----------------------------------------------------------------------------------- counter = 0 '----[ Program Code ]------------------------------------------------------------------------------------- Main: DO GOSUB GPS_Fix 'Get GPSRMC statement from pin 0 SERIN 0, n4800, [WAIT("RMC,"), DEC2 hh,DEC2 mm,DEC2 ss, SKIP 1,DEC3 sss, SKIP 1, status, DEC2 LatDeg, DEC2 LatMin, SKIP 1, DEC LatMinD, SKIP 1, LatSign, DEC3 LonDeg, DEC2 LonMin, SKIP 1, DEC LonMinD, SKIP 1, LonSign, SKIP 1, DEC dest(1), SKIP 1, DEC2 dest(2), SKIP 1, DEC degr(1), SKIP 1, DEC degr(2)] DEBUG "$GPRMC,", DEC2 hh, DEC2 mm, DEC2 ss, ".", DEC3 sss, ",", status, ",", DEC2 LatDeg, DEC2 LatMin, ".", DEC LatMinD, ",", LatSign, ",", DEC3 LonDeg, DEC2 LonMin, ".", DEC LonMinD, ",", LonSign, ",", DEC dest(1), ".",DEC2 dest(2), DEC degr(1), ".", DEC degr(2) CR GOSUB AddSign hh = hh + 1 'adjust to CET SEROUT 16, n9600, [DEC2 hh, ":", DEC2 mm, ":", DEC2 ss, ".", DEC3 sss, " " ] wVal = (LatMin * 1000 / 6) + (LatMinD / 60) 'convert to min/seconds SEROUT 16, n9600, [REP "-"\LatDir, DEC2 LatDeg, ".", DEC4 wVal, ", "] wVal = (LonMin * 1000 / 6) + (LonMinD / 60) 'convert to min/seconds SEROUT 16, n9600, [REP "-"\LonDir, DEC LonDeg, ".", DEC4 wVal, CR] LOOP '----[ Subroutines ]-------------------------------------------------------------------------------------- GPS_Fix: SERIN 0, n4800, [WAIT("GGA,"), SKIP 36, DEC1 Fix] ' find Fix value 'DEBUG "Fix : ", DEC Fix, CR IF Fix > 0 THEN ' test is GPS fix is there and set led 1 high HIGH 1 RETURN ELSE counter = counter + 1 'DEBUG DEC counter, CR IF counter = 10 THEN ' Output NO FIX only once every 10 seconds SEROUT 16, n9600, ["NO GPS FIX", CR] counter = 0 ' Reset counter to 0 ENDIF HIGH GpsFixLed ' Flash until GPS fix is found PAUSE 500 LOW GpsFixLed GOTO GPS_Fix ' Loop until GPS fix is found ENDIF RETURN AddSign: IF LatSign = "S" THEN LatDir = 1 ELSE LatDir = 0 ENDIF IF LonSign = "W" THEN LonDir = 1 ELSE LonDir = 0 ENDIF RETURN
Gr,
Ernst
I've started 4 separate projects now and all have stranded due to lack of speed/space/variables etc and its getting a bit annoying so to speak.
How does the propeller cope with this. What are its limitations is this? is there a good comparison chart of some kind where these differences between stamp and propeller are layed out?
It would be nice to just finish one project without having to cope with all these frustrations all the time.
The Propeller is completely different. It has more memory (32K bytes) although the program and data have to share the 32K. Programs (like on the Stamps) are quite compact. There are some objects in the Propeller Object Exchange that do a lot of the work already for NMEA parsing. The Propeller is much much faster than the Stamps and has 8 identical processors that can all be used at the same time (usually for doing I/O). Unlike the Stamps where most of the I/O is built-in as statements, the Propeller uses pre-written objects to provide the complex I/O. For example, there are several objects available that will do buffered serial I/O, some at speeds up to 1MBaud. The Propeller can store data and programs directly on an SD card as PC-compatible files. There's an object that will handle up to 32 servos for you and is used as the basis of Parallax's Propeller Servo Controller. The Propeller can generate VGA video and/or TV (NTSC or PAL) video.
If you're doing GPS projects, you'll be very pleased that you did. You might find a bit of a hump in the initial learning curve - things like debugging are more difficult with the Prop than the BS2. But once you get those things under your belt, the GPS stuff will be FAR easier with the Prop. And of course the forums are here to help you with the learning curve stuff.
Well I came as a total n00b in electronics a 5 months ago and i took the hurdle of learning the Stamp so I think I'll survive ;-)
I took a look at the spin language and the beginners books and i'm confident to learn it. By accident i just sold my professional experiment board and the board of education so i can start totally fresh and without a big gap in my wallet
The bigger challenge, I think, is getting things set up so that you can see output while you debug your program. Not that big a deal, but it's not a complete "gimme" like it is with the Stamp units. But I'm sure you'll manage it without too much trouble, and again, the Forums are here to help.
