Trying to build a tank.....proffesional science board question?
Gave up on flyer idea and going to build a tank...yes an actual tank that will shoot stuff with a paint ball gun.....dont ask. My question is how can u hook up a battery to the parallax science board?
I think that board is best for what i want to do, tank will have tracks and ill need powerful enough motors. only two boards i have are the science board and the bo-bot one that i might use for the turret but otherwise doesn't fit well into this project.
I'm planning on using like a small motorcycle battery or something like that, not sure, I'm going to bring this up to my Robotics teacher today but was wondering if anyone else had simple solutions to this.
I've never used the prop science board, but I assume it is propeller powered and that's why you posted in this forum? I just use the 5v regulator connected directly to the 11 to 14vDC system the car has (depending on if the alternator is rotating or not) . I haven't ever had an issue with the regulator not being able to bleed off enough current to maintain 5v. Of course it gets stepped down from 5v to 3.3v after that for the propeller. You could even use a 9v regulator before the 5v regulator to be thorough.
12v battery --> 9v --> 5v --> 3.3v --> propeller
If it were me, I would use a 9v regulator to cover my butt or a current limiting resistor with a 12v zener as a fail safe "pop off valve". I think the inexpensive 9v regulator is the simplest choice.
Like turbosupra, I'm not familiar with a Propeller board called the "science board". Apparently it has a breadboard. The only Propeller board I know of that comes with a breadboard (that has been released), is the Propeller Demo Board.
Could you elaborate a bit about which board you have?
Do you know what kind of treads you plan to use? There are a couple of options I'm familiar with.
The least expensive option are these Tamiya tank treads. You'll need a couple of motors to power them. You could use continuous rotation servos (forum member, Amanda has done this) or some other geared motors.
Another option is the Rover 5 chassis. I'm liking the Rover 5 more now that I've figured out how to use its encoders. The Rover 5 comes with four motors.
Vex makes some treads. I have a set but I haven't made a bot to use them yet. I think they look and feel pretty good. Again, you'll need a set of geared motors to power them.
Lynxmotion makes and sells some really nice looking tracks. Amanda has also used these.
You mentioned you have a BOE-Bot board. Does this mean you also have a BOE-Bot? If so, a good place to start would be to learn to control the BOE-Bot with your Propeller board.
I'm a fan of treaded vehicles and hope to build one myself soon. I look forward to watching your progress.
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/PPDB/List/0/SortField/4/ProductID/515/Default.aspx
It sounds like he has a BOE also.
Thanks Publison. I have two within three feet of where I'm sitting and still didn't think of it when trying to think of Propeller boards with a breadboard.
I don't think the PPDB comes to mind when I think of controlling a robot. It would need to be a pretty big robot to fit one of those on/in it.
P.S.: Pf, a paintball gun? I say, if you're gonna do something stupid, y'do it REALLY STUPID!!! BAZOOKAAAA!!!
Have you thought about what treads you'll use?
There are some treaded robots on Let's Make Robots that use bicycle chain with other materials to make the track.
Gordon likes to reuse treads from toy tanks.
Plus there are the options I listed earlier.
I hope you keep us up to date on your progress.
for now im just going to use my boe bot to build the program, i got the tank tracks for it so i should have those today, i cant build the bigger one yet but thats ultimatley the goal of the project. Im mostly experimenting with developing advanced atominess behavior to limit the robots dependance on a human pilot in combat, (trying to make it think for its self better), i really dont even need to mount a real gun on it, could easily build with using a LED to represent firing a gun but it sounded more fun with the paint ball gun.
