MMA7455 acclelerometer with Basic stamp2
hi ,
im facing problem with the accelerometer MMA7455 when i tried to program it with BASIC STAMP. I used the same code given in the "Downloads and Resources " menu and im getting the output as
X=-1
Y=-1
Z=-1
and there is no response from the sensor module....could you guys help me with the problem .
X=-1
Y=-1
Z=-1
VDD<----| VIN *
* CLK--|
>PIN 0 of Basic stamp
N/C
| N/C *
* DATA |
>PIN 1
N/C
| INT1*
* CS ---|
>PIN 2
N/C
| INT2*
* GND -|
>VSS
............ACCELEROMETER..................................................
I suggest you call Parallax Tech Support tomorrow. Sometimes a real-time discussion can uncover the differences between what you have and what you should have that can take forever in a forum setting.
