Line follower (28034) with 74hc165n
Hi all. Working on some code for a stingray based bot, currently tethered to a ppdb. I have a number of sensors working and the motors, but have a weird issue with a line follower and a 74hc165n. I have a public method that runs in its own cog that is responsible for reading a number of sensors (pub get). If I attempt to read the 165 in that cog, the result returned is always %0 or %11111111. However if read the chip in cog zero with the same statement it reads the data in correctly. I thought perhaps the stack space of the get method was too small so i doubled it and the issue persists. Any suggestions on where I should look next?
Here is the start method of the main program:
Here is the sensor reading method. hc165.read works just fine in the repeat loop above, but bombs when i run it from pub get...
This is the HC165 code... (Thanks to Microcontrolled for that!)
Thanks all in advance. I have been scratching my head over this one for a week or so already.
pub start
dira[motorin1..motorcsb]:=%11101110 'motor pin output exceb csa/b
DutyCycleA := DutyCycleB := 50
outa[motorENA]:=1 'turn it on
outa[motorENB]:=1 'turn it on
period:=50
PWM.Start 'sound and motor control
pst.start(115_200,pst#DEFAULT) 'debug
cognew(dubug,@stack) 'debug
cognew(get,@stackb) 'get most sensors
dira[speaker]:=%1 'enable speaker
brownout 'startup sound
clk_scale := clkfreq / 500_000 'set clk_scale based on system clock
MM2125.start(MMxpin, MMypin) 'Initialize Mx2125
waitcnt(clkfreq/10 + cnt) 'wait for things to settle
MM2125.setlevel 'normalize position
hc165.start(hc165SHLD,hc165CLK,hc165CLKINH,hc165SER) 'start line reader
HM55B.start(compassEnable,compassClock,compassData) 'start compass
repeat
ilf := hc165.read
pub get
repeat
'xbeedata := xb.rxDECtime(100)
distance := ping.Millimeters(PINGPin)
'ilf := hc165.read 'unable to run in same cog? why?
mmx := MM2125.Mx 'get RAW x value
mmy := MM2125.My 'get RAW y value
mmra := MM2125.ro 'Get raw value for acceleration
mmra := mmra / clk_scale 'convert raw acceleration value to mg's
mmt := MM2125.theta 'Get raw 32-bit deg
mmt := mmt >> 24 'scale 32-bit value to an 8-bit Binary Radian
mmt := (mmt * 45)/32 'Convert Binary radians into Degrees
mmxt := MM2125.MxTilt
mmyt := MM2125.MyTilt
RawHeading := HM55B.Theta ' Read RAW 13-bit Angle
CorrectHeading := Calibrate.Correct(RawHeading) ' Calibrate Correct Heading
Deg := CorrectHeading * 45 / 1024 ' Convert 13-Bit Angle to Deg
' Note: This only makes it easier for us Humans to read
VAR
byte data
byte SHLD,CLK,CLKINH,SER
word chipcount
PUB Start(_SHLD,_CLK,_CLKINH,_SER)
SHLD := _SHLD
CLK := _CLK
CLKINH := _CLKINH
SER := _SER
dira[SHLD]~~
dira[CLK]~~
dira[CLKINH]~~
dira[SER]~
PUB Read
return ReadExplicit(SER)
PUB ReadExplicit(serial_pin) | i
outa[CLKINH]~~
outa[SHLD]~
outa[CLK]~
outa[SHLD]~~
outa[CLK]~~
waitcnt(clkfreq/300 + cnt)
outa[CLK]~
outa[CLKINH]~
'repeat i from 1 to 8
repeat 8
outa[CLK]~~
data := data << 1 + ina[serial_pin]
outa[CLK]~
waitcnt(clkfreq/1000 + cnt)
return data
I think you would need MUCH stackb space for your get method...
-Tommy
but I think you may not need PST, and FullDuplexSerial.. at the same time.
OBJ ' motor : "UK1122" Ser : "FullDuplexSerial" 'cog1 started in XB (listed in this obj section fyi) MM2125 : "Memsic2125_v1.2" 'cog2 HM55B : "HM55B Compass Module Asm" 'cog3 Calibrate : "HM55B Compass Calibration" 'no cog PWM : "PWM_32_V4.spin" 'cog4 ping : "ping.spin" 'no cog pst : "PST Debug LITE" 'no cog ' XB : "XBee_Object_2" 'no cog uses FDS cog hc165 : "165" 'no cog 'cog5 debug cog 'cog6 get sensor data cogYou are correct. FDS is not used right now as the XBee object is turned off. It is called via that object to provide communication services. For debugging I prefer PST Debug, it offers some really cool functionally. I may be able to replace the FDS object used in the XBee code with debug light, but since PST Debug will be commented out when i go mobile with the robot i probably wont bother.
I haven't gotten any further with my issue yet. Ill look into the lock functions today and see if something there is useful.
