Propeller PONG - for the Quick Start board
First there was PONG, then came the rest of the industry.
Besides being something to mess with, I wanted to see how code running in different cogs would interact.
ESPECIALLY something like a keyboard driver.
Those kind of things take time and I was curious about how well they could hook up.
I'm tossing this little ditty up on the board for a discussion piece.
By the way, MY keypad driver is still too flaky to trust here, so I'm instead using a cut down version
of one from the Object Exchange. ButtonMenu111212a.
PONG (sorta)
Bat the ball back and forth and score a point when your opponent misses.
The end buttons on the QS board are the paddles.
It is SUPPOSED to speed up each pass, but that's where it ran into trouble.
With the speed up running, it would start missing the keys after about 4 passes (one way each).
I (obviously) don't claim this is pretty code, nor even presentable (other than as a student).
But it does play - sorta. :^)
It will be interesting to see what my betters make of it.
So, without further fanfare,
PONG
and the Touch pad driver
PONG (sorta)
PONG
CON { Pong01.spin - March 9, 2911 - Richard Lamb}
_CLKMODE=XTAL2
_xinfreq = 5_000_000
Right = 1
Left = 2
ButtonR = 0
ButtonL = 7
SpeedStart = 150
SpeedInc = -0 ' -33 locks out the buttons after about 4 passes!
SpeedMax = 100
OBJ Touch: "TouchButtons"
VAR
LONG MS001, Buttons, delay
BYTE ledByte, button[8]
BYTE PointsRight, PointsLeft,First, Last, LED
BYTE SpeedBall, X,Y,Z, A, B, C
BYTE Server, Direction
PUB SetUp
delay := clkfreq / 100 ' used by Buttons object
Touch.start( @delay, @Button ) ' send address of Buttons
MS001 := CLKFREQ / 1_000 ' define 1 millisec
outa[ 16..23 ] := $00 ' 000000 '
dira[ 16..23 ] := $FF ' 111111 '
Pong
PUB Pong
ClearAll
ChangeDirection
Server := Left
Repeat
BallMove
if Direction == Right ' to the Right
if Button[ButtonR] == 1 ' we hit it! speed up and return
if SpeedBall > SpeedMax
SpeedBall := SpeedBall+SpeedInc
ChangeDirection
else
ScoreRight ' missed it by that much..
elseIf Direction == Left ' to the left
if Button[ButtonL] == 1
changeDirection
else
ScoreLeft
A++
Pri ScoreRight
PointsRight++
if PointsRight == 4 ' winner!
Repeat 10
outa [16..23] := 011111
waitMS(50)
outa [16..23] := 000000
waitMS(50)
ClearAll
else
'show score
Repeat 10
Repeat x from 23-PointsRight to 23
outa[x] ~~
waitMS(50)
waitMS(50)
SpeedBall := SpeedStart
Pri ScoreLeft
PointsLeft++
if PointsLeft == 4 ' winner!
Repeat 10
outa [16..23] := 111000
waitMS(50)
waitMS(50)
ClearAll
else
Repeat 10
Repeat x from 16 to 16+PointsLeft
outa[x] ~~
waitMS(50)
waitMS(50)
Pri ClearAll
PointsLeft := -1
PointsRight := -1
PUB ChangeDirection
If Direction == Right
Direction := Left
else
Direction := Right
PUB BallMove
First:= 16
Last := 23
else
First:=23
Last :=16
repeat Led FROM First to Last
outa [LED] := 1
WaitMS(SpeedBall)
outa [LED] := 0
WaitMS(100)
PUB WaitMS(W) 'wait for W milliseconds
W := W*MS001
WaitCNT (W+cnt)
{cut down version of the pad code in ButtonMenu111212a.}
CON
BUTTON_PINS = $FF
PUB Start(delayAndBytesPtr, buttonPtr)
buttonAddress := buttonPtr
cognew(@Entry, delayAndBytesPtr) ' Launch a new cog to read samples
DAT
org
Entry
rdlong WaitTime, par
mov addressBase, par
'add addressBase, #4
mov outa, #BUTTON_PINS ' set TestPins high, but keep as inputs
mov Wait, cnt ' preset the counter
add Wait, WaitTime
Loop mov counter, resetLoop
mov stickybuttons, temp
mov temp, zero
innerLoop or dira, #BUTTON_PINS ' set TestPins as outputs (high)
andn dira, #BUTTON_PINS ' set TestPins as inputs (floating)
mov reading, #BUTTON_PINS ' create a mask of applicable pins
waitcnt wait, waitTime ' wait for the voltage to decay
andn reading, ina ' clear decayed pins from the mask
or temp, reading
or stickybuttons, temp
djnz counter, #innerLoop
mov addressTemp, buttonAddress
'wrbyte stickybuttons, addressTemp
'add addressTemp, one
mov bitCount, #8
:Bit shr stickybuttons, one wc ' shift off the bit to write
mov temp2, zero
muxc temp2, one ' make temp2 either one or zero
wrbyte temp2, addressTemp
djnz bitCount, #:Bit
jmp #Loop
zero long 0
one long 1
resetLoop long 4
temp long 0
counter long 0
buttonAddress long 0
reading res 1
waitTime res 1
wait res 1
stickybuttons res 1
addressBase res 1
addressTemp res 1
temp2 res 1
bitCount res 1
