There has got to be a better way!!
Hi folks!
I have a device that has a set of 8 cascaded 74HC165's that are all set up to be active low. The idea is that I want to be able to probe any one of the inputs with a grounded probe tip and have that pin show up on the TV screen. I have some working code, but I have always hated it, and I am looking for a better way of doing this. Here is what I have:
and so on, until you reach the end at:
Here is the snippet from my other object that does the displaying. What is going on there is it is taking the reference number from the top file and looking in a DAT block to display a label, not just the pin number:
What I am trying is a lot more compact, and in my head, it should work... but it won't. It just cycles the pins on the screen endlessly, even if there is nothing grounded out.
Does anyone have any suggestions on how I can clean and speed this up? I have been thinking on it for a while, and cannot figure out why the 2nd gen code is not working.
PUB GetProbe
''Probe check section
repeat
ifnot ina[PRB_Sw] ' Exit if PRB_Sw := 0
Green ' "Ready" LED on
disp.clean ' Clean up the display
Main ' Return to main testing loop
ShowTime(1) ' Refresh time from RTC
InData[0] := !SerIO.ShiftIn1 ' Poll input register set #1
InData[1] := !SerIO.ShiftIn2 ' Poll input register set #2
if InData[0] == %1000_0000_0000_0000_0000_0000_0000_0000 ' Scan for first Input active
TPData := 1 ' Assign the variable
disp.Point(TPData) ' Display it on the TV
if InData[0] == %0100_0000_0000_0000_0000_0000_0000_0000
TPData := 2
disp.Point(TPData)
if InData[0] == %0010_0000_0000_0000_0000_0000_0000_0000
TPData := 3
disp.Point(TPData)
if InData[0] == %0001_0000_0000_0000_0000_0000_0000_0000
TPData := 4
disp.Point(TPData)
if InData[1] == %0000_0000_0000_0000_0000_0000_0000_0001
TPData := 64
disp.Point(TPData)
PUB Point(TestPoint)
text.str(string($0A, 23,{ ' Probe Flag B
}$0B, 06,{
}$0C, 03, {
text.str(string($0A, 23,{ ' Disp. Point Number
}$0B, 06,{
}$0C, 05))
text.str(@labels + (MAX_CHARS+1)*(TestPoint-1))
repeat
repeat x from 1 to 32
if InData[0] > %1000_0000_0000_0000_0000_0000_0000_000
disp.Point(x)
InData[0] <<= 1
repeat x from 33 to 64
if InData[1] > %1000_0000_0000_0000_0000_0000_0000_000
disp.Point(x)
InData[1] <<= 1
repeat x from 1 to 32 if (InData[0] <-= 1) & 1 disp.Point(x) repeat x from 33 to 64 if (InData[1] <-= 1) & 1 disp.Point(x)
The expression (InData[?] <-= 1) & 1 rotates the top bit into position 0 and checks there. There are other ways to achieve this, e.g. checking for < 0 then shift/rotate etc. HTHHrmm... good point. that is most likely the bug right there. I had to clear off my work bench and switch gears to a different project, but hopefully I will be able to check this out soon. I will get back to you as soon as I know for sure.
@kwinn
They are not PASM. just good 'ole spin.... and I would like to keep them intact as much as possible becuase they are used pretty heavily elsewhere in the program, and I would hate to have to re-write a large chunk of this just to clean up my crappy code writing in one spot.
Works like a charm. Thank you very much for this quick drop in snippet.
@ kwinn
Also an excellent idea. I can use something like that to display multiple connections at the same time, if I get crafty with the code. Maybe I'll work on integrating that feature later on... and I will retain that idea for other projects down the road.
But for now, on to the next assignment.
