Milling PCB's
Who has mastered this so far with their home machines? I have a Probotix comet CNC and have done lots with it so far. But i have not done pcb milling.
I use Diptrace to design PCBs. What is the process from their to get them to my cnc?
CNC sofware i have is VCarve and Cut3d from Vectric.
What software is required to created the gcode file?
Also, DipTrace will directly produce a drill file that Mach3 will load to drill your holes, and it can also export DXF files of the silk screen layers - if you have a pen attachment you can use micro-sharpies to draw the silk.
These are the bits I use for cutting the traces: http://www.drewtronics.net/
This is the first PCB I did: http://www.youtube.com/watch?v=PPPoKnK6aiY
The biggest circuit I've done so far is for the room lamp, here: http://www.facebook.com/media/set/?set=a.10150172173803973.344728.671403972&type=3&l=4320ebfe4f
There's a well written article here: http://www.chembal.com/cnc/mechanical-pcb-etching
He uses Eagle, but the methods are very similar.
This is more than impressive! :thumb:
-- Gordon
EMC2 has some rotation features that would work for two sided boards.
Jason, do you have pictures of any of your finer detailed work?
I noticed your room lamp board used all DIP chips.
I'd love to see pictures of your TSOP milling.
It was for a 1mm spaced ribbon connector for a CDROM motor. Unfortunately I don't have any pictures of it and it's the only thing I've done that was that small. The end of the video shows a decent scale shot. I'm currently using a 60 degree bit, but a 30 would be better for fine pitch work because you can cut a little deeper but still keep the isolation paths narrow.
