Acquiring data via DDE using 'io' channel (Very Urgent)
Hello,
I need to acquire data as does 'streaming mode', it means obtaining 1024 measures into one package, and after obtaining another package with others 1024 measures.
I need to work in 'streaming mode' because the PropScope's transfer data velocity is not fast enough to characterize the data that is going to be studied.
I was discussing with Hanno in the thread "DDE connexion" about this topic; he concluded that the only option I have is to acquire "io" channel, which has 1081 points (Why not 1024?). The problem is that "io" Channel " doesn't have calibration or scaling applied" as Hanno said.
In the thread "DDE conexion" Hanno told that he will try to upload the corrected software with this error solved for Channel 1 and Channel 2, and I am still waiting for it.
Please I need urgently to obtain calibrated and scaled "io" Channel for a DDE.
Here I add two pictures. It is possible to observe the signal generated (with PropScope) and the acquired data using "io" Channel through a DDE.
Compairing signal generated with signal obtained it is easy observe what I am mean.
Luis
Luis
