Propeller Interface with 5v control signals
I have written some Basic Stamp apps and used interface boards such as motor controller, solid state relays, stepper motor control boards that need a 5v signal. The Propeller only has a 3v signal. How do I interface with the 5v peripherals? Thanks
You'll find many posts on this subject - here is one to get you started...
http://forums.parallax.com/showthread.php?127546-A-Cheap-easy-way-to-interface-Prop-with-5V-Peripherals
Most of the time a 3.3V signal is enough to drive 5V circuits, but if you have a lot of intermittent problems try using a level converter.
